BT-016 Front Question
Folks,
I am trying to buy a set of BT-016s for the R1100S at motorcycle superstore. I was given this choice:
O.E. Tire Size Codes:
120/70ZR-17 E = 2008 Suzuki GSX-R750
120/70ZR-17 C= 2011 Kawasaki ZX10R
120/70ZR-17 J = 2008 Kawasaki ZX-10R
120/70ZR-17 M = 2008 Suzuki GSX-R600
120/70ZR-17 U = 2009 Ducati Monster 1100
120/70ZR-17 L = 2009 Kawasaki ZX-6R
120/70ZR-17 N = 2009 Suzuki GSX-R1000
120/70ZR-17 B = 2011 Kawasaki Z1000
120/70ZR-17 AA = 2011 Suzuki GSX-R600
120/70ZR-17 G = 2011 Suzuki GSX-R750
Any thoughts?
Thanks,
Jim Moore
Jim Moore
Jax, FL
'01 R1100S
'07 CBR600RR
Old 04-24-2012, 02:13 PM
Gone Bush
twodear's Avatar
That shop must have a huge inventory to stock every conceivable variation of every tyre size made by Dunlop.
I'd choose the one that was fitted to a bike closest in weight and use - none of those listed are all that close though. Maybe the Z1000 or Monster 1100?
If enough is enough and more is better then too much should be just about right.
Member of AAAA (Association Against Acronym Abuse)
'22 H-D 'F' outfit, '46 Indian Chief outfit, a couple of early Honda Benlys, "BUBba" - R1150GS Adventure
Old 04-24-2012, 03:12 PM
Mine are an "f" series which I was told is a universal not an OEM application but if I had to choose I'd go with the U or the B
Old 04-24-2012, 05:55 PM
LeftCoast Peter's Avatar
I'd go Michelin PR2.
2008 HP2S Sport Touring
2009 525 Beta RR
North Vancouver
Old 04-24-2012, 06:31 PM
NakedRider's Avatar
You shouldn't have a problem finding a universal tire from a place like azbridgestone. Any shop that sells them should be able to help.
If this is your first "go round" with the BT016 just know that the front wears out before the rear if you do any canyon riding.
'09 BMW R1200R
Old 04-25-2012, 07:03 AM
Honda GL1000 current ride
Martin Glasser's Avatar
They are working well on my Triumph for a "value" tire. Don't take that application chart too serious. You got 17" rims and it fits? should be fine.
Old 04-25-2012, 09:01 AM
Oh try cycle Gear.. You got those in Florida, right?
Old 04-25-2012, 09:02 AM
CoffeeGuy's Avatar
Yes. What he said.
Old 04-25-2012, 09:33 AM
Thanks guys. I found the generic BT-106 Pro on a different page. $310 for a front and two rear BT-016s. You need the MC superstore code M71-BRIDGE5
Jim Moore
Jax, FL
'01 R1100S
'07 CBR600RR
Old 04-25-2012, 01:28 PM
roger albert's Avatar
F is the normal choice, but any of those will work fine.
Haven't seen heavy front wear. Even on the track, where one can load the front more heavily than on any street, the rear goes first (and even on a week motored bike, like and SV or other middleweight)
99 R11S w/ BBP, InDuct, Öhlins, PVMs, Braking, SJ-Filter, ZTech, HIDs
D675 R90Cafe R60/2 M900 SV650-SS CBR150R XR125 & CRF175 Motards
OnRoad OffRoad Cycles, Austin, TX: BMW, Ital, Suspension, Electrics
Dealer for K-Tech, JRI, GP Suspension, Penske, Öhlins, RaceTech, Elka, Wilbers, IKON & Works
www.ororcycle.com
CMRA EXPERT #841
Various Formula 5, 6 & 7 championships 2006-2012
A3, Navigator,
Old 04-25-2012, 01:37 PM
Gone Bush
twodear's Avatar
+1
it is a rare circumstance that I have to replace the front every time I change the rear - more likely I'll be changing two rears for every front.
Naked's canyons must have lots of stopping and cornering but little hard acceleration - or mixing a touring rear with a qualifier front.
Old 04-25-2012, 03:35 PM
Gasteropod Rider
Meeni's Avatar
I don't know specifically about the BT16, but often the OEM tire is significantly dumbed down compared to the real deal.
Old 04-25-2012, 04:28 PM
NakedRider's Avatar
I've never seen this before either. This is the only tire. I usually get about two rears to a front.
I have a NoMar changer and change the tires for several riding friends and they all had the same issue. Another forum in the San Francisco area had people claiming only 1,500 miles from their front! At least I got further than that.
My understanding is the new BT-016 has a front that wears about 60% better. It could be that it wears better now-a-days.
The multi compound tires can wear weird. Sometimes the sides wear quicker than the middle if you do a lot of canyon riding. When that happens you get a tire that's shaped like a "V". Plenty of tread in the middle but the sides are shot.
'09 BMW R1200R
Old 04-26-2012, 08:08 AM
