High revs needed from a stop?
Hi Guys. I test rode a 2004 R1100S yesterday. Beautiful bike and rode like a dream, however, it quickly became apparent that this bike needed significant revs from a dead stop to prevent lurching, say 2,500 to 3,000. Once underway, everything seemed great, with silky clutch & tranny action. I assumed that this engine would have tractor like torque from idle! Loved the bike but am concerned with the start procedure. Is this one of the many BMW traits (quirks)? T.I.A.!
Underwater basketweaver
That doesn't sound quite right. Explain this lurching behavior below 2500rpm please.
'05 R12GS '08 HP2 Sport |
When taking off from a dead stop, the bike needed what I consider a rather significant amount of throttle or it would buck. I killed it at one corner by not supplying enough throttle, but when revved up, it would pull away cleanly. It was like it had a very high first gear, and since I've never ridden a BMW before, I don't know if this is a particular trait of an R1100S. I've noticed on some threads that this bike is not known for it's low down torque, but I've never ridden a bike that needs as much throttle to pull away from a stop.
Are you sure you rode a R1100S and not a S1000RR? Did the cylinders stick out like two sore thumbs?
Memento Audere Semper |
Talk Less, Say More
Location: Moab Utah. Home of wierd red & orange radioactive stuff...
Probably user error and unfamiliarity.
cRaIg CaRr 2010 F800GS. 2000 Dyna FXDX. 2013 Rubicon schoolbus. 1995 Sierra. 1978 928. Schwinn Homegrown. 22 pairs of shoes. 4 bottles of beer. Time Marches On: 2007 R1200S, 2000 R1100S, 2003 Dakar, Buell 1125r, 2001 F650GS. 1999 F650. ALL GONE |
my $0.02ct
Unlikely to be the R, but in case that would be an real issue: 1- Massive valve or even cylinder wear/non balance- lost enormous amount of compression 2- cylinders fire way ahead of timing required, higher revs needed just to get going, I'd blame some custom/faulty commander or spark plugs not working (too big of electrode gaps) |
Do not take too seriously
If Otto2 has never ridden a boxer before, I am not at all surprised. First time I got on mine on the test ride, I stalled it too. Coming from a Japanese 4 with the traditional wet clutch, the clutch on the R was very finicky: very abrupt and almost like an on/off switch compared to what I was used to. Add to that the rather long first gear of the S, and it takes some getting used to.
Once I got used to it, it was just as easy to modulate as any other clutch and I wouldn't even give it a second thought, but I can see how a first timer could get caught out with it. |
I always thought the S was a relatively easy bike to idle away from a stop.... appropriately-low 1st gear, nice clutch engagement, and good engine torque from low revs. If you're an experience rider, I would be surprised if you'd find a "normal" S to be abnormal in its departure characteristics. If you've never owned a twin before, you might find the low-RPM characteristics a little rougher than a four, but nothing dramatic.
Sounds like something is wrong. Has the bike been fooled with with respect to ECU, power commander, fueling, air filter, exhaust, etc.? A lot of guys "hop up" their bike to the point that they fuel miserably at low RPM. (They don't run much better at high-RPM either, but they're completely convinced they've added mega-horsepower.) - Mark |
Jim Moore Jax, FL '01 R1100S '07 CBR600RR |
Ride Free or Die
If you ease out on the clutch so slowly that it begins to smell like an 18-wheeler at the end of a 7% downhill run, you may need to make some adjustments to your clutch technique. There is a French guy that has a mod for adding a digital gear indicator if you gear problem continues. Enjoy your ride.
Nobody says it is. But for the very first time on a BMW boxer it is sufficiently different to make it not surprising someone stalls it a couple of times. The dry clutch of the R is not nearly as linear as a Japanese wet clutch.
Ride Free or Die
The proper trainer for learning how to use the clutch on a 259S is to drive an old VW Beatle.
it's beetle and i have one.
beatles were those guys who made records, or slowly eat your house. you're right though. i've always thought that the two of them were very similar, yet it's still not difficult to get going with a small amount of throttle. this might help. pro motocrossers hear it so often, most mumble it in their sleep: "Practice your starts." |
I've found that this bike does require a little extra throttle to get going from a stop than any other bike I've ridden.
Also, however, if it's bucking and stuff, I feel like that bike is due for a tune-up, particularly a throttle body sync. It's amazing how rough the engine can run directly off-idle when they're out of sync, even though at higher ranges things seem "fine". As for the transmission, despite what others have said, I also think this bike's tranny is incredibly smooth shifting compared to most. Just clunks nicely into each gear. More often than not I can't even feel it, which I can't say of most other bikes I've ridden. |
In the traffic I use 2 gear. Easyer than changing 1-2 gears all the time. So to move smoothly from 2 gear in the traffic it takes about 2000-3000 rpm
Talk Less, Say More
I think you guys are making too much out of this.
Although, if we knew where Otto's bike was someone could go ride it... Perhaps Otto can give more information... But I doubt there's anything wrong with it....
Since I've had 40+ years of only Japanese wet clutches, I'm beginning to realize that the lack of dry clutch experience is the culprit. Thanks to all for the thought provoking commentary.
