No Info on (t)his member
At 9k miles, ( depending how it's been ridden ) it may just not be broken in yet. Another reason to not get 40mpg.
_________________________ jeff clark 99 R1100S 82 Alfa Romeo Spider Veloce |
Man it's flat out here!
Fuel consumption rate is dependent of several usage factors. One you haven't mentioned is what altitude is your riding area. The higher you are the lower your consumption rate and vise-versa. I suspect low altitude for you?
You'll know your in a low consumption rate altitude when you buy "premium gas" and it's ~89 Octane versus ~93 Octane in a low altitude area. A naturally aspirated engine cannot develop maximum pressure (nor peak rated horsepower) in the cylinder at high altitude and thusly the gasoline stations sell lower octane fuel there and it won't hurt your engine at all. Since the engine cannot develop maximum power at high altitude it consumes less fuel under high demand than it would at low altitude and high demand. If you have a Turbocharger it's obviously not going to work that way since the engine can develop maximum cylinder pressure even at high altitudes. This is where a Knock Sensor proves it's worth. The ECU sees the signature knock frequencies and incrementally retards the spark timing till the knock frequencies go away. For example, the last time we drove in Colorado our VW Passat 2.0T had no problem passing slower (normally aspirated) cars.
"Intent, in the pursuit of truth, is prior to content, or to the availability of it. The love of truth and the willingness to submit to its demands is the first step." - Ravi Zacharias |
Question for the OP.
What RPMs and gears are you typically using? When I first started riding my new-to-me '04 BCR, I was spinning the engine at higher RPMs and using lower gears. Not up near redline, but the Laser exhaust produces such a great sound around 5000-6000 revs that I wasn't upshifting as much. I was surprised at mileage in the low to mid 30's Now that the new has worn off I am spending more time in 4th to 6th gears and mileage is around 40. Just my experience- your results may vary. ![]()
John & Cathy '92 K100RS '04 R1100RS BC Jen's ZX6R Johnnie's 800ss |
R111S - I think my name might be a bit of a giveaway - I'm an expat living in Seoul, South Korea. Usual rides are pretty low elevation. Even given the not so high altitude I still feel the fuel economy to be lower than other R11S riders on here.
Sugarhillctd - The last couple of tanks I've rode on I've intentionally kept the RPM's lowish in order to check the fuel economy.. probably around 3-5K RPM on average. wiggledbits - did you straight up remove your O2 sensor? I'll do some reading on the Techlusion. Anyway I'm going to report back once I've tweeked the valves/TB timing, hopefully with some good news. Thanks all. |
Between the motor bolt-ons I have on the bike, Sprockets, Y pipe, Techlusion I have lost ~5MPG on average. Stock I got an all-time high of 51 from riding all slab but averaged ~43MPG all around. Now I am consistently 38MPG.
2004 R1100S 1999 Ducati 750 SS Tricked Out 2001 Ducati 750 Sport 1995 Kawasaki KX80 1988 Suzuki DR600 Last edited by wiggledbits; 06-04-2012 at 11:12 AM.. |
Don’t believe everything you think! I don't suffer from insanity, I enjoy it! 2000 red R1100s, 1983 Gold Wing Aspencade, 2003 CRF450R, 1996 KLX 650, 2006 Ford F250 super crew long bed |
Pretty bike. I like matching bags.
FYI, mine is an '04, about to roll 77k, and gets low to mid 40's for MPG (I can squeeze 48 out of it if I ride like an old man), depending on how much highway I do / how much right wrist I give it daily. On very cold mornings I'll occasionally pull the "choke" lever so it doesn't stall, but most of the time a throttle blip that turns off the battery light will do the trick. That is my understanding as well, but I really don't get why it's got a cable running to the engine compartment area and it's not just a switch... |
RBMann- Movies are my life. * 2000 S, color-Salmon 100K+ * '09 F650GS twin * '83 GPZ 550-gone to a newbie * '75 CB400F-retired to AZ. |
Thanks.
R1100s
Gps mount
Is the a GPS mount on bars? Been trying to work out how to mount one on my R1100s
[QUOTE=Nitro;6773412]First you might want to do the zero=zero TBS procedure, synch the throttle bodies, and set the idle to about 1500 RMP.
1500?!!! Haynes manual says1050-1150rpm. Mine varies betwerrn 1000 and 1100. |
Can the owners of stock 2004 R1100S, that get over 40 MPG, tell me what CCP they have.
My 2004 R1100S gets only 33 MPG and I have a white CCP (30-86-87). Thanks. |
What's a CCP? mines an '04 with all the trimmings and I got 42 mpg on my last tank.
CCP = Cat Code Plug. Involved in regulating fuel delivery.
"Wow I'm an idiot, thanks bikerfish!" Harleys are like opinions, every a-hole's got one! Ride safe, ride lots. 2001 R11S "lite", with a few mods. 2009 F800GS. has a better saddle. |
For poor fuel economy also make sure that brake calipers are working properly. Dragging brakes will effect your mileage.
Nick '05 R1200RT, '04 330CIC '00 R1100S '95 R100R Classic '02 F650CS |
those of you running twinspark bikes ('04 and newer) with mpg in the 30s- that is not right, you should be in the low to mid-40s, no question, even at sea level. better at altitude (my buddy gets upper 40s on his, and that's with a Laser system, which dropped him a few points.) my fuel mileage was crap when i first brought my bike home (light coming on at 115 into a full tank. a careful TBS and i was up into the mid 40s, sea level operation. surprised how much of a difference that made. i have to flog the snot out of it to drop it into the 30s, and running a full Laser system with chip.
My O3 BCP gets about 42 mpg with Lennie's sprockets, K-bike regulator, Brisk plugs, SJBMW super intake and 100 octane gas. No vibration whatsoever up to 6k rpm and very little after that.
| Tags |
| economy, efficiency, fuel, r1100s |
