P.S. The BMW allen head tool is a tighter fit that even a Craftsman. This is one area where good tools are critical, as has been discovered.
Yep. Trying to install Lennie's sprockets. Originally used too long a hex wrench and messed up the hole a bit. Then cut off a piece of hex and used a 3/8" drive unsuccessfully. Last try was the hex w/an electric impact wrench--results as shown above.
I have two replacement bolts in hand but have not decided whether to proceed and possibly make the bike unrideable or simply eat the cost of the sprokets. IF I decide to proceed, I think I'll try one of these first. If that fails, then I'll try one of the external "easy offs" that Nail24 suggested. Then . . . BTW, living in Hawaii means there is no winter, non-riding project time.
Phil Y, Kapolei, HI 04 BCR, 06 Buell Blast (grandson's first bike) "There are old riders, and there are bold riders, but there are NO old, bold riders!" -My first MSF instructor, too many years ago Last edited by Phil Y; 07-07-2012 at 12:21 PM.. |
I'll try to find the number for you, I do know it's a TRW Wendt-Sonis, 6mm allen head, I believe. With shipping, I recall that it was about $45. Ridiculous. Personally, I'd feel comfortable with either the (real) Craftsman or Snap-On
Whoops, it's a 10mm, not a 6mm.
unsafe at any speed
Have used the external ones at the shop many times to remove rusted out, rounded off fasteners. They work very well...
Bill Swartzwelder 2006 BMW R1200GS 2010 KTM 690 ENDURO R 1969 BSA StarFire |
I have had great success removing stripped internal hex fasteners by oing as others suggested, find a torx bit that is larger, some creative grinding to make the teeth a chisel point on the leading edge would help.
Usually I drive the torx in, but in case of the cams I don't think that would be advisable. Best advice I have seen is button it up and be happy with stock. Disappointing yes, but a ton cheaper than a major repair should a bad situation go worse.
Richard 2010 F800GS '04 R11BXA, '01 F650GS, '98 CBR600F3 track bike, '75 RE-5, '76 RE-5, '81 GS400E. Also residing in the barn my son's bikes: '89 GS500ES, Ducati Monster 620 dark |
Gone Bush
Glad I wasn't the first to suggest bashing with a hammer. If the JB weld trick fails, then bashing in a tapered hex key, I'd next bash with a cold chisel to try and drive the HSHCS anti-clockwise.
Last resort? spot weld a hex key in place. But that's me...
If enough is enough and more is better then too much should be just about right. Member of AAAA (Association Against Acronym Abuse) '22 H-D 'F' outfit, '46 Indian Chief outfit, a couple of early Honda Benlys, "Otis" - Disposable R1200S track bike, "BUBba" - R1150GS Adventure |
unsafe at any speed
I have mig welded a nut that fits over the head of the bolt with good results. then use regular socket that fits the nut.
One of the key pieces of information to take away from this thread is the importance of using the proper fitting tool when working on these boxers. If it doesn't fit you must quit. Didn't I hear a phrase similar to that a number of years back in a LA courtroom.
Richard, at this point this is my first choice! Least painful and fraught with no pitfalls other than the normal oilhead quirks!
Phil Y, Kapolei, HI 04 BCR, 06 Buell Blast (grandson's first bike) "There are old riders, and there are bold riders, but there are NO old, bold riders!" -My first MSF instructor, too many years ago |
If you got a set of Lennies seconds, you can probably fine a buyer for them now that he sold out.
R1100S
+1 for the welding a nut to the bolt head, might use a TIG as less chance of spatter etc. If the bolt head is 14mm then get a 14mm nut to fit over the head and weld it all around the bolt head as I think that you will only get one chance.
Thanx Dave |
Use the external. No hassle. I put the same size bolt in my 8" vise and clamped the bolt down as tight as possible. My set is Blue-Point { snap-on}. The 17mm external works great even on the smooth outer suface. Your going to replace the bolts anyway. tjs
Seeing that you got the Snap-On extractor, use a 30"-36" long quality extension bar. When using with the wheel locked, slowly bounce it a little harder each time each direction. Don't just push suddenly and steadily. If it works, and it should, Lennie's sprockets will be WELL WORTH the effort -- you'll have a different bike on your hands, one you'll love. Good luck.
P.S. My bad, with an extractor, bounce in only one direction to break loose. Was thinking of an ordinary allen head.
Registered Agitator
So Phil, got it loose yet or decide to close it up & consider as is ok?
I just received my Lennie's seconds sprockets in the mail about a week ago. Had not really even considered this modification potentially going bad.
Does anyone have that P/N for the preferred BMW tool that should be used to remove the cam sprocket bolt? If it is not necessary to spend the $45 for one 10 mm driver bit I would obviously prefer not to. I would definitely buy a Snap-on or some other quality brand before attempting the install. Phil - I am curious as well, did you continue with the buggered bolt extraction or abort the sprocket swap? |
Misfit
N. |
