Order Online or Call:
888-280-7799
McAfee SECURE sites help keep you safe from identity theft, credit card fraud, spyware, spam, viruses and online scams
Porsche | BMW | Mercedes | Audi | Volkswagen | Saab | Volvo | Mini
  Search Pelican Parts:
View Cart | Project List | Order Status |  Help
I wanna Live 'til I die!
signit98's Avatar
Send a message via AIM to signit98
Originally Posted by Phil Y View Post
What do you think of heating the general area and putting an ice cube on the bolt head immediately before trying to extract it?
See if you can find liquid nitrogen somewhere... or sport icing spray... if all else fails, get a can of compressed air (the stuff they sell at staples, for computers) and hold it upside down when you spray...target the bolt head.
The bolts will scare you when they come lose... it sounds like you ripped them.
Good luck.
Ralf Wilkowski
Light travels faster than sound. This is why some people appear bright until you hear them speak.
www.itwasnotme.com
2000 Suzuki DR-Z400S - 2001 HD Sportster 1200S - 2005 R1200GS
Old 07-17-2012, 09:58 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #81 (permalink)
No one has had to use heat to release the camsprocket bolt to date. Your explaination as to how the hexbolt got "goobered" up doesn't necessiarily mean you need to use heat now. If the stripped bolt external surface extractor can allow sufficient torque with a pull bar, you should make short work of the job. Don't forget to set up this project just as Lennie outline in his instructions.
Old 07-17-2012, 10:35 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #82 (permalink)
signit98's Avatar
And you know that how? Do you have a registry for that?
Ralf Wilkowski
www.itwasnotme.com
Old 07-17-2012, 10:55 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #83 (permalink)
Registered Agitator
sgoodwin's Avatar
Phil I've used heat many times & never cooled the bolt, just keep the heat to the perimeter until hot & torque loose with your nifty new tool.
Old 07-17-2012, 12:50 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #84 (permalink)
It has not been reported on any of the websites, Ralf. And, I don't think Lennie would have kept this a big secret if it was an issue. His instructions include much of the learning curve that has been associated with installing the rocket sprockets. The registry is the use of thread search. As you are certainly aware, the use of cold and hot are contained in many maintenance procedures. I was not dissing your suggestion.
Glad you had a nice visit to Paonia.
P.S. Check Lennie's responses in this thread.
Old 07-17-2012, 01:38 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #85 (permalink)
kpolito99's Avatar
I really do not think it is necessary to cool the head of the bolt.
I hope someone was kidding with the LN2 comment. Liquid nitrogen is not a good idea. Not trying to be a know it all or bash anyone but cooling metal to -320F/-195C (77K for tech types) is a great way to make the situation worse. Most materials become extremely brittle and a thermal quench with LN2 may cause the head of the fastener to shear completely off the shank when loaded.
Simply heat the area surrounding the head of the fastener. The large washer will promptly conduct the heat from the cam gear into the camshaft. We are not talking a lot of heat with an acetylene torch or anything. No parts should begin to glow or get white hot.
Just a slight rise above ambient temperature should allow you to break loose the threads.
Old 07-17-2012, 01:58 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #86 (permalink)
Phil Y's Avatar
OK, has anyone tried to "pin" the flywheel to lock the engine? I fab'd a pin from this site but could not locate the hole w/the flywheel at TDC--even tried a small hex wrench just to feel for the hole. Nichts! No bad jokes, pls!!
Phil Y, Kapolei, HI
04 BCR, 06 Buell Blast (grandson's first bike)
"There are old riders, and there are bold riders, but there are NO old, bold riders!" -My first MSF instructor, too many years ago
Old 07-17-2012, 08:21 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #87 (permalink)
tjs tjs is offline
If the one you made is the right dimensions it should work. Make sure the TDC mark is centered in the inspection hole. Pull the sparkplugs,put the trans in 6th gear. With the tool in place, Use the rear wheel to jog the engine back and forth ever so slightly. You will feel the tool move forward when it goes into the hole in the clutch carrier. I put a point like the factory tool has on the one I made. I know it works because I also have the factory tool shown. 2cnts from tjs
Old 07-17-2012, 09:02 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #88 (permalink)
Phil Y's Avatar
tjs, is the pin about 3/8" (little less than 1cm) in diameter?
Phil Y, Kapolei, HI
Old 07-18-2012, 09:03 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #89 (permalink)
The item you are dipicting is a locating mandrel not a locking pin. BMW does make a flywheel lock; but, it is normally used after the transmission has been separated from the bike (bike splin in two).
This is the tool that locks the flywheel. You can break the camsprocket bolt and then just snug it up. then use the tool you made to determine TDC. Then proceed with the sprocket change folliowing Lennies instructions.
Old 07-18-2012, 01:58 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #90 (permalink)
tjs tjs is offline
that tool was not the tool Phil was depicting. but if one were to use it ..... all you have to do is remove the starter to engage tool #11 5 640 onto the clutch carrier ring gear. tjs
Old 07-18-2012, 02:23 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #91 (permalink)
signit98's Avatar
You don't really need any special tools... I have done 5 set of sprockets now and have never needed anything but 5th gear and the brakes applied...
However, I usually try to keep the amount of work involved, to a minimum... so, if your objective is to create yourself even more work that you already have... go for it.
Ralf Wilkowski
www.itwasnotme.com
Old 07-18-2012, 02:27 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #92 (permalink)
Now Available for Ordering:   101 Projects For Your BMW 3 Series 1982-2000  [more info]
signit98's Avatar
You don't really need any special tools... I have done 5 sets of sprockets now and have never needed anything but 5th gear and the brakes applied...
Ralf Wilkowski
www.itwasnotme.com
Old 07-18-2012, 02:28 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #93 (permalink)
tjs tjs is offline
Phil.
A 3/8 drill measures .3740" The BMW tool measures .3405" where it passes through the hole in the clutch carrier. tjs
Old 07-18-2012, 02:34 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #94 (permalink)
Phil Y's Avatar
OK, thanks tjs.
@Nail: my Haynes manual has a "Haynes Hint" which indicates that the flywheel can be locked with the tool depicted in the site I posted in #87.
Phil Y, Kapolei, HI
Old 07-18-2012, 03:06 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #95 (permalink)
wiggledbits's Avatar
Send a message via AIM to wiggledbits
My $0.02.
The bolts do break lose with a loud CRACK! They must use considerably more torque in the factory as mine had zero lock-tight.
I stood on my rear break and the motor still spun. That is how I got in trouble replacing with Lennies. Yes I had good pads, rotor and a recent flush. A stop pin is excellent insurance at this point. If I was to do it again I would use a pin.
Heating it up will help and since you're not at an optimal point right now any help to reduce the torque to get them loose is good.
Take a deep breath, you'll get the job done.
The sprockets are worth the change.
2004 R1100S
1999 Ducati 750 SS Tricked Out 2001 Ducati 750 Sport
1995 Kawasaki KX80 1988 Suzuki DR600
Old 07-18-2012, 03:32 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #96 (permalink)
Misfit
I gotta say, I've spent more time reading this thread then I think it's going to take you to undo that bolt. The suspense is killing me!
Courage man! Get in there and have at it!
N.
Old 07-18-2012, 06:08 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #97 (permalink)
I think I'll go out tomorrow and crack the torque on the camsprocket bolt just to record the sound.
Old 07-18-2012, 06:14 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #98 (permalink)
signit98's Avatar
You do that... and then we'll spend the rest of the year talking about how much the repair cost was...
Ralf Wilkowski
www.itwasnotme.com
Old 07-18-2012, 06:56 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #99 (permalink)
Phil Y's Avatar
Sorry guys, it'll have to wait for a little while longer. I get a good bite with the busted nut socket but the engine still turns in sixth, even after having bled the rear brake. My clutch must be slipping because the rear wheel does not turn. :-((
tjs, one more time, pls. Still have not been able to locate hole on flywheel. Is the proper hole close to the edge of the clutch housing near the starter or is it about 1 3/4" inwards and 2 1/2" higher from this hole, in front of the airbox? If the latter, I'll have to remove the airbox (gas tank, etc.) in order to gain access.
Been trying this one w/o success (starter solenoid is in foreground), Second hole is also visible in this pic. It looks accessbile but is not.
Sorry for the poor quality of this one of the hole in front of the airbox. For ref, the throttle body inlet is in the foreground and the airbox is on the right:
REALLY appreciate the advice and encouragement. Been ready to quit several times but thanks to this board, I'm giving it at least one more try!
Phil Y, Kapolei, HI
Old 07-18-2012, 08:50 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #100 (permalink)
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
Copyright 2011 Pelican Parts - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
