R1100S Spiegler Brake Line Kit
My bike is 2002 with integral ABS ...
Question: Is installation same as stock or does the configuration of the lines change with Spiegler? Thinking front, mostly as rear is just one straight line.
Kent Christensen
Albuquerque
'12 R1200RT, '02 R1100S, '84 R80G/S
'01 Boxster
Old 09-03-2012, 01:12 PM
I just did my 2001. Fairly simple but still took a few hours including bleeding.
You change everything including the "T" fitting on the fork.
Pick up a bag of small nylon ties to finish the job.
Mike
Old 09-04-2012, 05:20 AM
Misfit
Noblehops's Avatar
Mike
Hmm, almost everything as I recall - there is a short hard pipe between the T and the left front line - that stays.
N.
Nils Menten - Tucson, Arizona, USA* 2001 R1100S "Light", gone but not forgotten. http://tinyurl.com/zv3tpc5
I Do Vapor Blasting! Visit restocycle.com for information.
Ikon shocks for your BMW! https://www.ikonshocksusa.com/
Old 09-04-2012, 06:12 AM
Comes with the T then. Thanks for replies.
Kent Christensen
Albuquerque
'01 Boxster
Old 09-04-2012, 09:19 AM
Misfit
Noblehops's Avatar
Yes, confirmed, comes with the T.
N.
Old 09-04-2012, 01:38 PM
Misfit
Noblehops's Avatar
N.
Old 09-04-2012, 01:39 PM
Hello All, another question about the Spiegler brake line kit.
The MAX BMW fiche shows the rear Brake Hose 34 32 2 331 901, which is the same part for No ABS, ABS, and IABS.
But the Spiegler site (and other brands) do not show brake lines for IABS, only for No ABS or ABS II.
If the rear brake hoses are interchangeable, is there a reason why they are not listed for IABS by Spiegler?
I plan to change the rear hose on my 2004 with IABS soon, because of a draggy caliper, would like to hear from anyone who's made this upgrade sucessfully.
Thanks!
Jeff
2004 R1100S...1986 R80 G/S...2003 Ducati M800Sie...1981 R100RS (Sold)...1977 Kawasaki KE100 - 1st Bike
Old 09-04-2012, 07:43 PM
mendoje:
I also have a 2004 R1100S with ABS. I changed both the front and rear with the Spiegler front/rear kit S-BM0124.
Spiegler now sells the the clutch line kit (must be a new product) .
The money I spend on this motorcycle, I could have leased a car for less.
Old 09-05-2012, 08:38 PM
wiggledbits's Avatar
Send a message via AIM to wiggledbits
I think IABS and ABSII are one in the same.
Old 09-06-2012, 11:29 AM
I think not..I believe one (IABS) may be servo assisted and ABSII is not..and way simpler.
I await correction...
Old 09-06-2012, 02:39 PM
I may be the one corrected... A quick look and some references come up about ABSII being non-integrated.
Old 09-06-2012, 03:50 PM
Hi Groceryrun,
When you apply the brakes, do you hear a very loud whining noise? If so, that would be from the power assist servo on IABS. If your 2004 has ABS, I'm pretty sure it's IABS, but can you confirm?
All, here's a good link on Anton's site summarizing BMW ABS1, ABS2, and IABS
systems:
ABS faults
Thanks All!
Jeff
Originally Posted by Groceryrun View Post
mendoje:
Old 09-06-2012, 07:20 PM
Hi Jeff:
Both the front and back brake calipers are labeled "BMW".
Whenever I use the brakes, the ABS unit whines, and does not stop till I release the brakes.
In my opinion, they are power-assisted brakes - if the engine ever stops, there will be minimum, and I mean minimum, braking power (as far as what I'm experiencing on my bike).
When I replaced the brake lines a couple of years ago, they were in very good condition as
far as I could tell. I still have them. I did not cut them open to see what the insides looked like.
What the brake kit did not come with, is the 14 inch EPDM tubing (please feel free to correct me If I'm wrong about the material) between the rear reservoir (fluid container rear) and the rear brake master cylinder.
I know you can buy it from BMW and Brembo, but I was hoping to get something fancy - like the braided hose with vinyl covering to match the Speigler kit.
I guess the reason the fancy hose would not be appropriate for this situation is because it has teflon tubing on the inside and teflon might not expand and compress when used on the master cylinder and reservoir fittings.
Old 09-06-2012, 08:47 PM
Thanks Groceryrun!
Old 09-07-2012, 04:38 PM
