Boxer Cup Belly Pan Without Paint
So, My Belly pan Before and After, Whatcha think???
WOW! Who'd a thought it would turn out so nice! That would look great on a black bike.
I see you
even better on a DDP! nice work!!
Si non potes inimicum tuum vincere, habeas eum amicum and ride a big blue trike. "'Bipartisan' usually means that a larger-than-usual deception is being carried out." |
Gasteropod Rider
Did you give it a coat of clear? It would improve shine and protect the carbon fiber from oxidation.
Registered Nut
Looks great!! I'm guessing you will be painting the inside black?
No try, do or not do
Looks like you did a nice job. What bike is it going on? I had a BCR and I liked the paint job on the pan, but if you scored the pan and are mounting it to a different R11S then it makes sense. I bought a full carbon belly pan for my R12S and ended up painting it. I like carbon accents, and knowing that parts are carbon, but I don't have to see all the weave. At some point it's too much.
2017 R1200GSW Rallye Shreddr Signature Model |
![]() ![]() BMW R1100S Carbon Fiber AspellCarbon.MP4 - YouTube |
Petie3rd
the carbon looks good , i would add some 3M film the the leading edges that face the front tire to reduce the chance of shattering the Carbon and abrading from small stones, possibly run a strip down the center you can buy the 3M film on Ebay in different widths you could probably use 2X 6 in. wide strips.
I would also suggest to paint the inside white and add the heat foil to near where the pipes run. White will not get as hot as black, it reflects heat and will show up leaks easier plus it looks really sano
^^^ Stan ^^^ 2019 BMW K1250 GS 2016 HD RK 1988 S4 Auto , Elfenbein Perlglanz, Pearl Gray 1982 5sp Met black and tan sport seats |
Gasteropod Rider
Yep, I have a home painted pan too, and it chipped very quickly at the chin, I wish I put 3M film early on.
BMW still sell the pre cut 3M film for the front of the belly pan. Just bought a set from the dealer myself. However the pre cut film ends 2/3 from top of the mid post between the two air scopes, so I recommend adding a bit more film. Good paint protection against road debris.
1999 R1100S Boxer Cup Replika replica 2011 HP2 Sport, full Akropovic |
Very nice job on the paint removal, clean up and polish! I second the tape idea, especially nice if you run through some wet paint on the road like a friend of mine did a few years ago over by Boone. There seems to be a lot if it on the roads in the Carolinas, not to mention if you should happen across a fresh tar & chip job!
2012 Ape Tuono V4 2008 Duc 1100 Hyper 2007 BMW R1200S (For Sale) 1992 Yam FJ 1349 www.hamptonsavannahs.com |
Misfit
Awesome project, great job! Looks fantastic, and as far as I know, unique!
N.
Nils Menten - Tucson, Arizona, USA* 2001 R1100S "Light", gone but not forgotten. http://tinyurl.com/zv3tpc5 I Do Vapor Blasting! Visit restocycle.com for information. Ikon shocks for your BMW! https://www.ikonshocksusa.com/ |
Thank you all for comments! Here is few more pix.
Inside I sprayed with heat resistant enamel ( paint) and on the front I put 3M film ![]() ![]() ![]() |
