1987 951
Severe Hesitation on R1200S
New to this bike. Bike has just shy of 40K miles.
In gears 3-6 it has a severe hesitation when you accelerate quickly. If you hold the throttle for several seconds or release the throttle slightly the hesitation is minimized. The bike idles fine, has a bit of a burble off throttle at low speed. Through some Techron in the gas, but thinking that this might be an issue where the throttle bodies need syncing. Any ideas would be appreciated. |
Talk Less, Say More
Location: Moab Utah. Home of wierd red & orange radioactive stuff... And 1 billion tourists.
First step would always be a good tune-up. Plugs, air cleaner, valve adjust, then throttle body sync. Or do free stuff first. Then take the troubleshooting from there if the problem still exists. But how can you know anything without eliminating those potential problem areas first?
cRaIg CaRr 2000 Dyna FXDX, 2001 Sportster Sport, 2000 R1100S,2007 R1200S,2015 rNineT,2015 Gold Wing, 2023 F850GS,2023 R1250RS, 2017 Triumph T100, 2019 Jeep Rubicon, 2005 Jeep Sport, 2001 Corvette, 1978 Porsche 928. 2001 GMC Sierra 2500HD, 22 pairs of shoes. 24 bottles of beer. |
Nickels to Donuts
Sounds exactly the same issue my friend had with his twin spark R1150RT.
It was a bad coil stick. What is a coil stick? It is part of the plug wire and serves as a mini-coil. You can purchase them and it takes a moment to install. For analysis, he found some shade tree test on the Internet that proved to be correct. Maybe one of the manuals covers testing a coil stick. Had to do something with RPMs dropping. Maybe a shop will tell you how to check. It was fairly simple and something I would do before setting valves, sycning throttle bodies, new plugs, .... Good luck, Nathan |
Talk Less, Say More
If I had just bought a bike with 40,000 miles on it like the OP did, you bet I'd be doing a complete tune-up on it. Ridiculous not to, unless maintenance records tell you otherwise.
No try, do or not do
i found that replacing the stock wheels with carbon ones, reduced hesitation immensely!
2017 R1200GSW Rallye Shreddr Signature Model |
1987 951
Thanks for all the responses. I'm going to start with Nathan's and finish with Sheddr's. With a tune up in between. Starting my 2nd shift job search that I will need to afford the new carbon wheels.
