andrisport's Avatar
Boxer Cup Belly Pan Without Paint
So, My Belly pan Before and After, Whatcha think???
Old 09-23-2012, 10:40 AM
WOW! Who'd a thought it would turn out so nice! That would look great on a black bike.
Old 09-23-2012, 10:51 AM
I see you
flatbutt's Avatar
even better on a DDP! nice work!!
Old 09-23-2012, 12:17 PM
Gasteropod Rider
Meeni's Avatar
Did you give it a coat of clear? It would improve shine and protect the carbon fiber from oxidation.
Old 09-23-2012, 12:55 PM
Registered Nut
Drews323i's Avatar
Looks great!! I'm guessing you will be painting the inside black?
Old 09-23-2012, 02:53 PM
No try, do or not do
shreddr's Avatar
Looks like you did a nice job. What bike is it going on? I had a BCR and I liked the paint job on the pan, but if you scored the pan and are mounting it to a different R11S then it makes sense. I bought a full carbon belly pan for my R12S and ended up painting it. I like carbon accents, and knowing that parts are carbon, but I don't have to see all the weave. At some point it's too much.
2017 R1200GSW Rallye Shreddr Signature Model
Old 09-23-2012, 03:57 PM
andrisport's Avatar
Yes, it will be black on the inside, and have protective heat foil.
Old 09-23-2012, 05:03 PM
andrisport's Avatar
I gave few clear coats and between coats -- wet sanding. 400, 800, and a 1000 sand paper, crazy hah??
Old 09-23-2012, 05:05 PM
andrisport's Avatar
Shreddr, I'm crazy about natural carbon fiber My bike is Full Carbon Fiber
BMW R1100S Carbon Fiber AspellCarbon.MP4 - YouTube
Old 09-23-2012, 05:07 PM
Petie3rd
Mrmerlin's Avatar
the carbon looks good , i would add some 3M film the the leading edges that face the front tire to reduce the chance of shattering the Carbon and abrading from small stones, possibly run a strip down the center you can buy the 3M film on Ebay in different widths you could probably use 2X 6 in. wide strips.
I would also suggest to paint the inside white and add the heat foil to near where the pipes run.
White will not get as hot as black, it reflects heat
and will show up leaks easier plus it looks really sano
Old 09-23-2012, 06:24 PM
andrisport's Avatar
3M film is a good idea! Thank you Mrmerlin for advice.
Old 09-23-2012, 08:17 PM
Gasteropod Rider
Meeni's Avatar
Yep, I have a home painted pan too, and it chipped very quickly at the chin, I wish I put 3M film early on.
Old 09-24-2012, 05:43 AM
Sophus's Avatar
BMW still sell the pre cut 3M film for the front of the belly pan. Just bought a set from the dealer myself. However the pre cut film ends 2/3 from top of the mid post between the two air scopes, so I recommend adding a bit more film. Good paint protection against road debris.
1999 R1100S Boxer Cup Replika replica
2011 HP2 Sport, full Akropovic
Old 09-24-2012, 11:43 AM
CarolinaBoxer's Avatar
Thumbs up
Very nice job on the paint removal, clean up and polish! I second the tape idea, especially nice if you run through some wet paint on the road like a friend of mine did a few years ago over by Boone. There seems to be a lot if it on the roads in the Carolinas, not to mention if you should happen across a fresh tar & chip job!
2012 Ape Tuono V4
2008 Duc 1100 Hyper
2007 BMW R1200S (For Sale)
1992 Yam FJ 1349
www.hamptonsavannahs.com
Old 09-26-2012, 04:13 PM
Misfit
Noblehops's Avatar
Awesome project, great job! Looks fantastic, and as far as I know, unique!
N.
Nils Menten - Tucson, Arizona, USA* 2001 R1100S "Light", gone but not forgotten. http://tinyurl.com/zv3tpc5
I Do Vapor Blasting! Visit restocycle.com for information.
Ikon shocks for your BMW! https://www.ikonshocksusa.com/
Old 09-26-2012, 04:46 PM
andrisport's Avatar
Thank you all for comments! Here is few more pix.
Inside I sprayed with heat resistant enamel ( paint) and on the front I put 3M film
Old 10-01-2012, 04:18 PM
