1987 951
Practically Non-Existent Rear Brake R1200
I have a new to me R1200S. The back brake is practically non-functional. It will slow the bike, but only with a fair amount of effort.
Is that a function of the ABS, or do I need to perform a pedal adjustment, or something else. Pads looks good. Any thoughts would be appreciated. Thanks Scott |
Do a search for the werner mod. Basically the pivot point of the rear brake binds up. The werner kit takes care of the problem. For now you could disassemble , clean, lubricate and when putting it back together watch not to make it to tight. I noticed on mine when doing the upgrade that as soon as I loosened the bolt a drop the rear brake worked.
Underwater basketweaver
Brakes? Pfft! All brakes do is slow you down.
'05 R12GS '08 HP2 Sport '16 GT4 |
I am not sure if the previous owner of my bike installed the Werner mod but he gave me the old bush that he had removed. Man did the BMW engineers really cheap out on that design.
![]() My rear brake works great now and while naturally it is far less effective than the front, it works as best as could be expected for a rear brake. |
Sergio;
Bet you were glad you had some good ones last week when you were driving your car!!! Glad you walked away, by the way!! Cheeers
09 HP2 Sport,07 R1200S,05 KTM 640 Adventure,00 KTM 520 EXC,82 R100S,72 Hodaka 125 Wombat |
Honestly it happened so far I don't even remember if I hit my brakes or not. I had just gotten on the highway too, less than a mile beforehand! I just remember hearing screaching tires and by the time I started to look over to my left, sideways truck into and over my car. Yikes!
There is a conversion kit for the brake. To make this work well
We're working on getting the next batch made and sent over now.
The shop Werner makes them at a bit backed up right now, but it IS in progress.
99 R11S w/ BBP, InDuct, Öhlins, PVMs, Braking, SJ-Filter, ZTech, HIDs D675 R90Cafe R60/2 M900 SV650-SS CBR150R XR125 & CRF175 Motards OnRoad OffRoad Cycles, Austin, TX: BMW, Ital, Suspension, Electrics Dealer for K-Tech, JRI, GP Suspension, Penske, Öhlins, RaceTech, Elka, Wilbers, IKON & Works www.ororcycle.com CMRA EXPERT #841 Various Formula 5, 6 & 7 championships 2006-2012 A3, Navigator, |
Roger,
I am in for one when you get them. Thanks |
How does this happen with a modern manufacturing co.? I am sure there is a brake dept. how could the engineer that designed this brake never try iy out, or anyone else?
Lane
2005 Boxercup, 2013 R1200GS Rallye, 2011 Triumph 675 Daytona, Honda MB5, 2011 KTM300xc, 1975 Bultaco, 1992 Beta, 1972 Aermacchi |
groundhog
I am in for one of these kits also.
I haven't tried stomping on mine with the ABS on or off but in just the first hundred "new to me" miles on the bike the rear seems fine. The nutso thing is the front or maybe I should say the lack of front end dive when hard on the front brake, too weird! Still haven't figured out how to set up for corners properly, no thread hijack intended, just a comment.
2012 Ape Tuono V4 2008 Duc 1100 Hyper 2007 BMW R1200S (For Sale) 1992 Yam FJ 1349 www.hamptonsavannahs.com |
I think that's a big reason why the magazine reviewers all complain about lack of feel with telelevered BMWs under braking. But back to the topic, even before the Werner mod, the rear brake on my R1200S is better than my new-to-me Ducati 996. The local mechanic says even when perfectly adjusted and bled, the rear still doesn't work well. He said Ducati's answer is "why are you using the rear brake?"
Mike '07 BMW R1200S '99 Ducati 996 '09 Husky TE450 |
LOL Mike, I'm so use to track days on my now sold GSXR rear brake really never enters my mind unless I'm waiting at a light or on gravel/loose stuff. I know some of the guys in the old FJ group use to actually induce a bubble into the rear brake to make it a little more numb and less prone to lock. Not sure about my Hyper, don't use it much either
I'm in for a the Werner kit too.
Tried just the rear brake only to slow down and not much helpful to reduce speed. Amazingly, even ABS engaged before I noticed much slow down. But I like the way it is to rely more on the front.
Paul from So. Cal. 07 R1200S 96 R1100RT |
Lane
2005 Boxercup, 2013 R1200GS Rallye, 2011 Triumph 675 Daytona, Honda MB5, 2011 KTM300xc, 1975 Bultaco, 1992 Beta, 1972 Aermacchi Last edited by 1100s nut; 11-07-2012 at 02:52 PM.. |
