Go Back   Pelican Parts Forums > 2- BMW Forums > BMW Technical Forums > BMW R1100S / R1200S Tech Forum
Anyone Running a 2.53 rear drive on their R11S?
This recent R11S that came to the shop about five weeks ago is turning into a interesting project of advance farkle and high top end due to a slick full length pan and removal of extras from the rear end of the bike. I am in the process of installing a 2.53 rear drive on it and was wondering if anyone out there is running one of these on their bike for long distance slab runs, better mileage, or less vibration at freeway speeds. Anyone running one of these? Curious as to how it launches with such tall overall.
Old 03-17-2013, 02:24 PM
so you zing it up and slip the clutch, like an old yamaha roadracer. looking forward to riding with you again, I have learned that old age and hard knocks tend to slow down a rider
Mike Kelly
Triple M Engineering
K12RS KLX650 XR400 KDX200
Old 03-17-2013, 05:28 PM
What is the 2.53 rear drive from...?
Interested to see how this goes, would be good to lower the rpm a little at cruz speeds, 70mph, 80mph, which would keep it under the 4k rpm vib level...
Jeremy
Old 03-18-2013, 02:22 AM
Jeremy, the 2.53 ratio is taken from the Cruiser units. The standard R11S is a 2.75.
Old 03-18-2013, 05:48 AM
Nitro's Avatar
That's just weird! I've always geared all my chained bikes shorter not taller! I find the gearing on the R1100S just perfect, I would not want it taller by any means tho. If anything, I'd like a shorter 1-3 gear, the rest is just fine.
Just think about acceleration and drivability you will be robbing away. On my RC51, I went 15/42 vs. the 16/40 stock. The bike now redlines in 6th at 155 mph, so I lose well over 20 miles/hour BUT from 0-155 there are no flat spots, drivability is vastly improved, and the bike is just plain more fun to ride.
Speaking of which, I went to bike week and rode a Harley Dyna Fat Bob and a Softail, speaking of tall-geared bikes!!! Gee, who needs a theoretical 170+ miles/hour on a cruiser! You can't even use the 6th gear unless you are going well over 90 miles/hour, and trust me anything over 80 on a cruiser is worse than a colonoscopy! The Softali by the way had very limited ground clearance and it did not brake for crap. The Dyna was actually a big surprise as it handled well and the brakes were adequate.
Memento Audere Semper
Old 03-18-2013, 07:19 AM
Why don't one of you Mensa members figure out what the difference would be?
Old 03-18-2013, 08:08 AM
Nitro's Avatar
Assuming a 180/50 tire, and a redline @ 8500 RPM, the gain with the taller gear is about 19 miles/hour to the top speed which due to aerodynamic drag and the engine power, I doubt one can actually see.
@ 6000 rpm, the taller gear (2.53) will go about 13.75 miles/hour faster.
Again, I'm of the opinion that with the tall gear the bike will ride like crap!
Old 03-18-2013, 08:42 AM
Dr. Curve,
You will be altering your gearing by 8% so your reduction in rpm for a given speed would be 8%. A cruise rpm of 4000 with stock gearing will be reduced to 3680 with the altered rear. A cruise rpm of 4500 with stock gearing will be reduced to 4140 with the altered rear, and so on.
Personally I always thought the R1100S felt a bit soft in first gear so you could expect it to be even more so with the altered gearing, which might be somewhat aggravating in hill country but of course less so on the slab.
My hunch is that the R1100S has insufficient power to realize any gain in top speed.
Old 03-18-2013, 05:10 PM
SeabeckS's Avatar
Location: Seabeck, Washington, 20 miles west of Seattle as the seagulls fly!
Uh, I don't think he's in search of more top speed or better perforamnce in the twisty bits...just a better cruising engine speed on the superslabs. Ya know, for those long distance jaunts? And if you can get the parts and have the ability to install yourself...why the hell not? And with the price of petrol now, again I say...why the hell not?
Old 03-18-2013, 07:44 PM
Well sounds good to me, Im very keen to see how this goes, maybe Im looking for a 1200C or something to wreck, lol...
8% Taller gearing doesn't seem much, but maybe make a fair difference...
Thanks for your answer to... Jeremy
Old 03-19-2013, 03:12 AM
Honda GL1000 current ride
Martin Glasser's Avatar
See that JIm? pelicans aren't all naysayers.. They have good math skills..
Old 03-19-2013, 03:22 AM
unsafe at any speed
wswartzwel's Avatar
Ha... Curve is all about top speed. read post 24 for a bit of history on the man.
Fuel pressure mod
Bill Swartzwelder
2002 R1100S Prep/2006 BMW R1200GS
1969 BSA StarFire
Old 03-19-2013, 05:18 AM
SeabeckS's Avatar
True that!
Old 03-19-2013, 08:01 AM
Stumbled across this while looking for other stuff I've been running such for a while now assuming you have a motor with all the bells and whistles on to pull the gear takes the bike to another level if you use your S for travelling on.
The link on post 12 made me smile
XR1000
K1200r Sport
XT660
Tiger 955
R1100s
Old 09-05-2017, 07:24 AM
04 R1100S
R1100S-Slick's Avatar
Hi,
So what happened to this thread. It was interesting. How did everyone willing to mess with their engine electronics finally make out? Any progress or conclusions to report in 09 2017?
Thx
Slick,
Old 09-27-2017, 04:39 AM
It was the final piece of jigsaw puzzle that I'd been after for years but you need all the other pieces to make the motor run well enough to pull the extra gear putting the higher gearing on a bog stocker it would just fall flat on its face.
The only down side I have found after years of ownership it takes some adjusting to the lack of revs as opposed to what speed you are doing it'll cruise at an indicated 100mph and not break 5000 revs two up with gear it gives around 55 mpg at between 90/100.
Although I have to say the new style injectors help modernise the bike as well.
XR1000
K1200r Sport
XT660
Tiger 955
R1100s
Old 09-27-2017, 07:10 AM
