Go Back   Pelican Parts Forums > 2- BMW Forums > BMW Technical Forums > BMW R1100S / R1200S Tech Forum
2003 r1100s
2003 R1100s missing or not firing on left cyclinder. What is most likely culprit or best place to start diagnostics?
Old 03-28-2013, 11:14 AM
Mark Estes's Avatar
Do the simple things first. Remove and switch positions of the stick coils, right to left and left to right. See if it's now not firing on the right cylinder. If so, you know you have a bad stick coil.
Mark
2004 R1100S, 1975 R75/6, 2005 Yamaha Majesty 400
"that spending was required to simply establish BMW in the world of WSBK from its previous position as a manufacturer who built bikes for a solidly geriatric customer base." -- SuperbikePlanet.com
Old 03-28-2013, 01:50 PM
BCR 285
Vinnyd's Avatar
^^ Mark said it, definitely check the stick coils, I had this problem on my '04. I bought two that way if I need another I got it on hand.
Old 03-31-2013, 04:57 PM
Does an '03 have stick coils?? Only dual spark engines do.
Old 04-01-2013, 03:36 AM
SSSSSS's Avatar
If you want to start simple try putting new plugs in or at least look at them to see if they are fouled.
1986 GSXR 750R Limited
2003 R1100S BCR
Old 04-01-2013, 06:26 AM
Brent
Ive actually had a bad coil in a single spark motor, as well as a army of
coil over's, in a 1150rt I picked up all 3 coils were fubar,
Old 04-03-2013, 09:30 PM
