R1100s
2004 Boxer Cup
![]() Need advice please on a rear stand for my 2004 Boxer Cup. Is a single sided one with holder into rear wheel sufficient, or double sided under rear pegs. It is just for garaging checking oil etc so rear wheel is off ground. |
I got a Wunderlich which works well but is not in stock right now. Maybe you can find something else that works. Good luck!
Phil Y, Kapolei, HI 04 BCR (not quite stock), 06 Buell Blast (grandson's first bike), 77 R100S w/sidecar "There are old riders, and there are bold riders, but there are NO old, bold riders!" -My first MSF instructor, too many years ago |
This one is from your neck of the woods: S-Lifter Motorcycle Stand BMW R1100S
Don't have any info on it, however. When I had my R11S I bought the BMW shop stand. Pricey, but worked well.
Mark Boucher www.touringsportbmw.com www.touringsportducati.com '04 1150GS '01 RSVR |
I highly recommend the BMW/Pitbull stand. It works with or without the belly pan installed (I use it for my 03 BCR). They are no longer available through BMW or Pitbull, but they do pop up on this forum occasionally. I bought mine used and was able to find the required spool kit through my local dealer.
2018 R1200GS Rallye 2005 R1100S BCR 2003 R1100S BCR #73 1998 R1200C 1966 R50/2 |
R1100s
BMWR502
Phil Y mfbRSV Appreciate help, may have to get one made, because of belly pan. Still trying to work out which model my BCR is, as it appears 2004s were blue white, made late 2004. |
Mitch1100-
The BMW/Pitbull stand does work with the BCR belly pan installed. ![]()
BMW r50. Is that lotus beside your bike? A buddy of mine has one...fun car!
On the stand, I wish I had the pit bull, that you use with the pan still on. I have the wunderlich, I believe, ....pan has to be removed. Lane
2005 Boxercup, 2013 R1200GS Rallye, 2011 Triumph 675 Daytona, Honda MB5, 2011 KTM300xc, 1975 Bultaco, 1992 Beta, 1972 Aermacchi |
You would be correct! It's an '06 Elise. Really, really fun car, but a little obnoxious for a DD. The bike is more practical in my opinion, at least in AZ. haha.
1100S--No need to remove pan for Wunderlich stand. See photos in link in my msg #2, above.
R1100s
BMWR502 Phil Y
many thanks can see how it fits in photos now liking the low center of gravity. Nice BCR |
R1100s
BMWR502 With the help of your great photos, having one made by neighbour. Will post result.
Cheers Phil |
I have one of the Wuderlich stands also (03 BCR). It isn't the most convenient to use. But, it's easy to remove the belly pan, while on the stand, for oil changes etc.
