Man it's flat out here!
R111S's Avatar
Stebel Nautilus 139dB Twin Tone Air Horn upgrade
As you all know the OEM Horn on the R1100S basically tells the Engine "uh...we're about to get hit".
Some of the BMW Owners in our local BMWMOA Club have upgraded to the Stebel Nautilus 139dB Twin Tone Air Horn. After having my ear drums split wide open by their thankfully short demonstrations I though it would be a nice upgrade for times in heavy city traffic among the cell-phone trancers and such. If you haven't heard one of these 139dB attention getters then you are in for a somewhat unpleasant surprise.
I installed the $62 Kit from (Excel Cycle Werkes) yesterday and it took about 2 hours at a leisurely pace. The Kit includes a Relay, Wiring cut to extra length, Crimp Terminals, 20A Fuse w/Fuse Holder, Shrink Tubing, Instructions, and all necessary Mounting Hardware for the R1100S.
Tools needed are Wire Cutters, Wire Strippers, Crimp Pliers, and standard Wrenches to remove the OEM Horn and mount the Stebel Horn. The kit includes a new Mounting Bracket w/Spacer and Bolts/Nuts/Washers. I also straightened the anti-rotation tang next to the OEM Mount Hole because it was interfering with the Stebel Housing.
I put the Relay and Fuse immediately behind the Fuel Tank. I routed the Air Intake Hose to the Alternator area.
Here's the Kit:
Here's the OEM Unit:
Here's the Stebel Unit (right side):
Here's the Stebel Unit (left side):
"What I've tried to do in the two books I've done, Signature in the Cell and Darwin's Doubt, is to show just how weak the materialist's hand is in explaining the key events in the history of life. ... We would encourage people to roll up their sleeves, do their homework on this." Stephen Meyer PHD
Old 04-18-2010, 04:43 PM
Dismembered
GotRoad?'s Avatar
I put one of those on my bike maybe 3 yrs ago & it's been great at getting attention when I need it. Since the wiring connections on the horn face down I made a weather cap for the horn's connectors by going to Home Depot and buying a 2" (if I remember correctly) dia. rubber cap. then cut 2 slits to push the connectors through and then used some rubber cement to seal the slits where I pushed the wires through and also to glue the cap to the horn body. It's worked well for me.
farkled '04 R1100S SOLD!
2012 Ducati Multistrada Pikes Peak (#072)
"It is difficult to get the news from poems, yet men die miserably every day from lack of what is found there" WC Williams
Old 04-18-2010, 05:51 PM
Gone Bush
twodear's Avatar
Is there a test of someones conversion on Youtube? I'd like to hear that before trying to source one.
If enough is enough and more is better then too much should be just about right.
Member of AAAA (Association Against Acronym Abuse)
'22 H-D 'F' outfit, '46 Indian Chief outfit, a couple of early Honda Benlys, "BUBba" - R1150GS Adventure
Old 04-18-2010, 10:03 PM
Stebel has audio clips of every horn they produce (from scooters and cars, to ships and trains) on their website.
2004 R1100S...1986 R80 G/S...2003 Ducati M800Sie...1981 R100RS (Sold)...1977 Kawasaki KE100 - 1st Bike
Old 04-18-2010, 10:21 PM
Like Gotroad? I had one on my 11S. Rode in some major Nova Scotia rain stroms and never had a problem with water. Didn't have the airtube installed. Not really a requirement.
I liked it so much that I installed one on my R1200Road Tank
Old 04-19-2010, 05:54 AM
No try, do or not do
shreddr's Avatar
has anybody put one of these on the R12S? I am not too big on honking the horn, but I must admit I feel embarassed by the sound that comes out of the stocker, its sounds like it ought to be on a scooter
2017 R1200GSW Rallye Shreddr Signature Model
Old 04-19-2010, 07:03 AM
Is you horn presently in front of the front shock? If so, make two fists and put them on top of each other and place them up there where the old horn is. I'll take about that much room to fit the Stebel.
Old 04-19-2010, 07:41 AM
I'd like also to upgrade the horn, but to be honest I almost don't use it. I'm looking for something simpler to install even if the sound is not super loud, just a little improvement over the stock one.
Do you guys know is there is any horn upgrade just replacing the stock horn?
I was thinking something about the same size that works with the canbus.
2011 S1000RR
2006 R1200GS
2013 CRF250L
2004 BCR. Sold
Old 04-19-2010, 12:00 PM
I am also looking at replacing my stock horn on my R12S. Anyone have experience?
Old 04-25-2010, 05:29 PM
My horn is currently behind the headlight, in front of the right hand fork. Looks like I've got some room to play with, though I'd have to remove the gas tank cover to see.
Have you done the install of the wires? I have never messed with a relay before and am concerned that I'd screw it up. Seems like the theory is:
Run a wire from the battery to the relay
Run a wire from the relay to the horn
Attach the button wire to the relay
Old 04-25-2010, 05:57 PM
TxCan01's Avatar
For you R1200S guys. Check out Nippy norman in the UK, he has pretty good descriptions of which horns fit what.
HORNS - STEBEL-NIPPY NORMANS - the No. 1 supplier of BMW motorcycle accessories!
Old 04-25-2010, 06:38 PM
I like the web-site. The only horn it appears they sell for the R12S is the Stebel Magnum. Looked for a review and here is what I found:
Stebel Magnum Horns - webBikeWorld
Not a very good review in my opinion.
Old 04-26-2010, 01:36 PM
I looked at Bob Hancock's 12S. There is more than ample room for the Stebel Nautilus up front.
Old 04-26-2010, 05:54 PM
Looks like Stebel doesn't have very good horns, at least for reviews.
Stebel Nautilus - webBikeWorld
Old 04-26-2010, 06:23 PM
I'm surprised with that review. I've never had a problem with the two that I've had on different bike.
Old 04-26-2010, 06:37 PM
R111S's Avatar
Mine is still working and as I said in my original post above there are several in our local BMW Club who have installed these kits. Most of them ride BMW R1XXXGS.
I'm not disputing what web-bike-world says - just telling my own experience.
Old 04-26-2010, 08:23 PM
Cambridge K
Cambridge K's Avatar
After two years - I got mine up & in my K12S - just got bike inspected - horn test - left a load in the service's guys pants - I told him SORRY - He turned & laughted at me - NOW THAT'S A HORN - you passed.
Old 04-27-2010, 01:03 PM
Snob Pirate
geothepencil's Avatar
Maybe the problems reported were due to inadequate wiring. They need good wire to work correctly.
geo
"She sips nitro... with Phase 4 heads! 600 horsepower through the wheels! She's meanness set to music and the ***** is born to run!" Barry, MFP mechanic
BMW/Yamaha/Suzuki
I've been ionized, but I'm OK now.
Old 04-27-2010, 01:20 PM
R111S's Avatar
I read somewhere that there are some Chinese counterfits of this horn in the marketplace too.
Old 04-28-2010, 07:52 PM
Tricked R12S
I have gotten conflicting reports....Will the Stebel Nautulis work on the R1200S ???
Old 07-27-2010, 06:45 PM
