-   BMW R1100S / R1200S Tech Forum (http://forums.pelicanparts.com/bmw-r1100s-r1200s-tech-forum/)
-   -   Missing shift up to 2nd: Occasionally (http://forums.pelicanparts.com/bmw-r1100s-r1200s-tech-forum/759244-missing-shift-up-2nd-occasionally.html)
Robert Au 07-04-2013 12:28 AM
Shifting up to 2nd occasionally producing false neutral, not real neutral with the dash light illuminated, fixed by going at the shifter again. Just removed peg lowering kit after 8 years, so it may be technique. Not Sure, over to the brains trust...........
JimMoore 07-04-2013 04:02 AM
Technique and /or your shifter is too high. Try lowering it a quarter-inch.
signit98 07-04-2013 04:57 AM
And check to see whether the little rod with the ball joint at the ends is loose, bent or worn.
ckcarr 07-04-2013 06:02 AM
New boots!
(I say only as a half joke...)
bradzdotcom 07-04-2013 09:08 AM
thinner socks so your big toe can really feel what's going on.
nail24fac 07-04-2013 09:14 AM
Pre-loading the shifter helped me with the hitting neutral between 1st and 2nd on both of my R1100S's.
Robert Au 07-04-2013 10:21 PM
I usually ride in bare feet, it's hot over here!
bradzdotcom 07-05-2013 04:05 AM
well hell, that explains it!
you're out of balance. your feet are too light.
you need to wear a tank top and shorts to balance things out.
then fine-tune it all with one of those silly chopper guy helmets.
for safety reasons, consider sunglasses too.
if you make these adjustments, and ride for a while, the occasional missed shift will quickly diminish in importance on your list of problems.
