gj938elm's Avatar
Helmet Lock Install
Stock helmet lock not very useful under seat... so, I ordered up a r1100rt piece and extra 1100s lock cylinder with a set of re-key pieces. Keyed the helmet lock and bags to match ignition. Helmet lock attached with a rubber-covered clamp & machine screw from hardware store.
No more carrying the helmet into the bar...
'04 r1100s
Old 10-06-2013, 02:02 PM
I see you
flatbutt's Avatar
sweet! how did you re-key the cylinder?
Old 10-06-2013, 03:19 PM
gj938elm's Avatar
Flat, I searched around on here, adv, and ibmwr:
Replacing BMW System Case Lock - ADVrider
R11 Bag Lock Modification
rekeying system cases (bmw saddlebags)
Ordered the key tumbler kit and new lock cylinder. Took 20 minutes or so fiddling with tumblers and springs. Did the bags at the same time - after having a separate key for 5 years... now, I like to go to the garage and open the bags, helmet lock, and turn the ignition on - with the same key - just for fun. Should've done this years ago.
'04 r1100s
Old 10-06-2013, 03:55 PM
Helmet Lock Install
Sweet. Nicely done.
'82 yam. seca turbo (retired ) '87 k100rs ( retired )
'99 r1100s abs w/ ohlins, motoyoyo clamps, 5.5 rear wheel, 365mm torque arm, ceramic coated exhaust, extra carbon bits, steel braided brake lines, wave rotors (cause you gotta stop, or slow down quickly) - good at the track.
Old 10-06-2013, 04:28 PM
Thanks I will have to look into lock setup the next time I'm at Max's.
btw that bike looks awfully clean
Old 10-07-2013, 01:50 PM
