diz plaz is cwazy
RIQUE's Avatar
6" wheel 1200
The fatter rear wheel on the R1200s looks pretty cool. Have any of you managed to swap from the 5.5 to the 6" wheel with major handling improvement. Is it a
plug an play swap or do certain mods need to be made?
Life rewards action, He who is not afraid is safe!
A Zest for living requires a willingness to die!
BWM R1100S 2004 (fat girl) BMW S1000RR 2011(skinny
BMW R1200S 2007 (stingger) Honda CX500TC 1982 (turbo)
Old 10-28-2013, 11:12 AM
Do not take too seriously
throttlemeister's Avatar
Should be a straight swap, but I'd switch to the /55 tire as well as the standard /50 will probably worsen the handling on a 6" rim instead of improve it.
BMW R1100S 'Bumble Bee' | HyperPro 3D F&R | motoyoyo clamps | Staintune | some other bits
BMW K1200S 'tri-color ICBM' | WP ESA rebuild to specifications | lots of other bits
http://www.sport-touring.eu | http://eurotravel.photos
Old 10-28-2013, 11:19 AM
careful there.
if done incorrectly, it can be kinda like the difference between...and...
'04 R1100s. I changed a couple o' things.
Old 10-28-2013, 11:40 AM
narrow tire generally has quicker turn in, wider is not always better as Brad illustrated.
Richard 2010 F800GS '04 R11BXA, '01 F650GS, '98 CBR600F3 track bike, '75 RE-5, '76 RE-5, '81 GS400E.
Also residing in the barn my son's bikes:
'89 GS500ES, Ducati Monster 620 dark
Old 10-28-2013, 12:20 PM
GDM GDM is offline
On the Road Again
GDM's Avatar
I had a comment about traction but I think I should just let it go.
Gerry
Old 10-28-2013, 12:34 PM
GDM GDM is offline
On the Road Again
GDM's Avatar
Rebound damping?
Couldn't let it go.
Old 10-28-2013, 12:41 PM
diz plaz is cwazy
RIQUE's Avatar
I was actually planning on installing the wider rim and the stock tire that BMW put on it.
Anybody know where to get a wide wheel? I tried at Max Motorcycles and other dealers but its not even listed.
Brad great pictures had a good laugh.
Old 10-28-2013, 05:22 PM
GDM GDM is offline
On the Road Again
GDM's Avatar
01 Silver rear wheel 6,00X17 1 36317683132 $987.34
Got this off the A&S microfiche site. Apparently it comes in black as well.
Trying to post the link (below)
A&S BMW Motorcycles Microfiche
Old 10-28-2013, 05:38 PM
GDM GDM is offline
On the Road Again
GDM's Avatar
Rique,
There is another set of part numbers, I have no idea why there are two.
Gerry
Old 10-28-2013, 05:40 PM
diz plaz is cwazy
RIQUE's Avatar
Got it. Thanks I´m thinking rear Ohlins first.
Old 10-28-2013, 07:11 PM
GREAT decision!
Old 10-29-2013, 06:45 AM
ohlins are a good choice, but why the rear first?
the front hits stuff before the rear finds out about it.
if you're only buying one...
Old 10-29-2013, 08:14 AM
kpolito99's Avatar
Originally Posted by GDM View Post
Rique,
Gerry
There are two sets of part numbers because the wheels are directional as indicated by the little arrow on the rim and BMW switches the swing arm from the left to the right side on various bikes.
I know this because I purchased an HP forged rear for my R1200S and the dealer was uncertain. If I am not mistaken K-bikes have the swing arm on the left side.
You will have the rest of your life to remember. But what you have to remember depends on what you do today.
Current ride - 2007 BMW R1200S
Past bikes/sold - 1999 BMW R1100S/1994 Honda VFR 750/1989 Suzuki Katana 750/1982 Suzuki Katana GS1000SZ
Old 10-29-2013, 10:36 AM
diz plaz is cwazy
RIQUE's Avatar
Thanks for heads up. It would majorly piss me off to get the wrong sided wheel all the way down hear!
Old 10-29-2013, 11:06 AM
diz plaz is cwazy
RIQUE's Avatar
The rear shock change on my S1000RR was the most dramatic change I felt when doing the swap. Rear wheel just dug in and traction was amazing. Not that the fronts are also fantastic but its just a first impression I got.
Old 10-29-2013, 11:12 AM
I've got a black used one that is like new. Check your PM.
JR
2000 Cagiva Gran Canyon
2007 BMW R1200S
Old 10-29-2013, 11:23 AM
Registered Agitator
sgoodwin's Avatar
Rique you're comparing a top shelf Ohlins fork to a second tier front shock, not the same as rear shock to rear shock. The effect of an Ohlins shock up front would probably be more dramatic than in the rear. I nearly had my Sachs rear shock set up as well as the Ohlins I replaced it with on my Aprilia Mille. I was actually surprised there wasn't a bigger difference when I installed the Ohlins. However when I replaced the front stocker with an Ohlins on my 1100s it was night & day difference all to the better.
Old 10-29-2013, 12:53 PM
diz plaz is cwazy
RIQUE's Avatar
Well, we are talking very different bikes. The effect I mention is not just my crazy idea. Its consensus across the S1000RR forum. You see the stock fronts on the
S1000RR are pretty good.
Old 10-29-2013, 06:26 PM
Registered Agitator
sgoodwin's Avatar
I agree on the 1000rr the rear shock would make a big difference as it already has an "A" grade fork but on the 12s I think the biggest difference would be with a front shock swap instead of a rear. With the stock front shock on the 11s it was harsh & would bottom out on big hits, the Ohlins eliminated both the harshness & bottoming in front plus added better tracking. Just my opinion of course but if I could only afford one at a time I'd start in front.
Old 10-29-2013, 07:26 PM
diz plaz is cwazy
RIQUE's Avatar
I´ll take your advice when it comes to shock order. I´m getting a rear wheel from a member on this forum so I guess the Ohlins will have to wait a bit. Cheers.
Old 10-29-2013, 08:04 PM
