Throttle cable/distrib. box inspection
I need some advice. It's about time for me to start putting my bike back together. While I have the tank off, the DME displaced, and have all that great access, I was thinking that I should look over the innards of the throttle cable distribution box. Is this a good idea or a bad one? Does it look like the insides of a Rolex?
What should one look for when inspecting the throttle cables?
Mine feel pretty good. No odd noises or binding. Throttles return with a snap and seem to operate very smoothly. I did notice that when the left TB bellcrank is against its mechanical stop there is a small gap at the right TB, maybe .050". I know that throttle sync is the important issue, I pointed this out as a FWIW sort of thing.
Should I just leave it alone? Does this require any sort of lubrication?
TIA
Old 12-18-2013, 01:33 PM
D Man
D Man's Avatar
The Bowden box can be a bit intimidating to some. Go for it if you are handy and patient. Mine had some sand inside, I cleaned and lubed with graphite powder. Oil/grease will only attract and hold the dirt. Check your cable up at the throttle handle, that's where mine started to fray.
Cheers
D Man
2001 R1100S Frost Blue
Trying hard to keep it legal.
Old 12-18-2013, 02:47 PM
Brent
not difficult to do but not usually a problem either.
Old 12-18-2013, 04:56 PM
You could replace the throttle with the new improved version. Requires kit of parts at handgrip as well.
Kent Christensen
Albuquerque
'12 R1200RT, '02 R1100S
'01 Boxster
Old 12-18-2013, 05:20 PM
D Man
D Man's Avatar
Never heard of this new improved version. Can you supply a link with more info?
D Man
Old 12-19-2013, 05:40 AM
D Man
They change the upper throttle cable at one point. that required a change to the handlebar assembly. You can see it on the MaxBMW fiche. Section 32, diagram 32-0965. You can't buy an old throttle cable any more, so you need all the new parts if you want to change your upper cable.
It's not a huge project. it might be a good idea to get it done if you're looking for something to do in the garage.
http://www.maxbmwmotorcycles.com/fiche/DiagramsMain.aspx?vid=51678&rnd=04302013
Jim Moore
Jax, FL
'01 R1100S
'07 CBR600RR
Old 12-20-2013, 01:51 AM
I replaced my cables at 50K. To tell you the truth, there was nothing wrong with the ones in there, I just thought it would be prudent. If I had to do over, I'd left them alone. The ordinal ones look pretty good. Just my 2 cents.
BMW R1150sR - Project Touring Bike
Ducati Hyperstrada - Mountain Road Slayer
Porsche 914-6 Vintage Race Car
Porsche 944 S3S (S3 Studie)
Old 12-20-2013, 03:41 PM
In some instances the original throttle configuration could see the cable wearing into the plastic. The new cable makes the 90 degree turn inside a metal tube that's part of the cable itself.
https://www.facebook.com/photo.php?fbid=483509418430921&set=pcb.10151796322181658&type=1&relevant_count=2&ref=nf
Kent Christensen
Albuquerque
'01 Boxster
Old 12-20-2013, 09:18 PM
D Man
D Man's Avatar
Kent, thanks for the photo.
D Man
Old 12-21-2013, 03:11 AM
