Question for those that have done an ABSectomy
I've been doing some research on ABSectomy due to a failure of my servo. My bike is equipped with the Tokico calipers rather than Brembo.
Has anyone done the ABSectomy on a Tokico equipped bike? Just wondering if they perform as well as the Brembos in a non-ABS conversion.
Thanks,
Tom
Old 12-26-2013, 03:58 AM
I wanna Live 'til I die!
signit98's Avatar
Send a message via AIM to signit98
They are pretty much identical... however, when you take the ABS pump out, you might want... scratch that, you WILL HAVE TO go to steel braided lines.
You will love the way your brakes work and never look back...
Light travels faster than sound. This is why some people appear bright until you hear them speak...
https://www.facebook.com/Uncommon-Adventures-by-Rick-Ralf-681965548931729
2005 R1200GS - 2006 Suzuki DR650 - 2011 Husky TE250 - 2014 KTM690 Enduro - 2022 Husqvarna Norden 901
Old 12-27-2013, 11:10 AM
Thanks Ralf.
I do plan on ordering up a set of stainless lines from Spiegler. I'm going to use a double banjo bolt at the master cylinder and run each line to a caliper.
I've seen about 3-4 different ways to deal with the lights and settled on separating the electrics from the mechanical servo and leave it in place.
Just gathering the parts and courage to dive in.
Old 12-27-2013, 03:29 PM
Registered Agitator
sgoodwin's Avatar
I agree with Ralf, the calipers are near identical & should work markedly better than before. I think the separation method is the easiest way also, fortunately mine is '99 & presented no such hassle so I could remove everything. The only hard part is unthreading the metal tubing through the frame to remove it, some tight clearances there. I did the same with the lines, double banjo at the master with 2 separate lines, I think this is the easiest to bleed. You will find great brakes after this is done. Dive in.
Old 12-27-2013, 06:08 PM
I just did mine. It's a piece of cake. Dont forget that you will need to order or fabricate the small hard line that connects the rear brake pedal cylinder to the connection fitting for the rear hose...item #3
I had forgotten all about this and had to fabricate one.
Old 12-27-2013, 06:19 PM
Registered Agitator
sgoodwin's Avatar
Yeah I forgot about that tube, I just happened to have one from a used non-abs rear brake line laying around when I did mine.
Old 12-27-2013, 09:02 PM
Thanks guys! Brake line tube ordered. Going to dive in as soon as I get back home from an extended trip.
Old 12-29-2013, 06:18 AM
absectomy made easy
I have a description with pictures partnumbers etc how to do this, unfortunately it is all in German.
I will need an e-mail address to send it.
Here we are already getting ready for new years eve celebrations. Have a good one.
rgds
Flying Dutchie
Old 12-31-2013, 05:43 AM
