diz plaz is cwazy
R1200S Ohlins stock weight springs
I wanted to confirm that the stock Ohlins that come with the R1200S are set for
176lbs with gear. I need to confirm this with Dan Kyle. Seems shocks are ready for me just need new oil.
Life rewards action, He who is not afraid is safe! A Zest for living requires a willingness to die! -------------------------------------------------------- BWM R1100S 2004 (fat girl) BMW S1000RR 2011(skinny BMW R1200S 2007 (stingger) Honda CX500TC 1982 (turbo) |
AKA nail24.Guest24
Rique, as I've been told, the 175lb rider weight is the way they come from the factory. Spring rates on the telelever aren't as important as the paralever. I think they are emulsion filled vice oil.
06 F650GS IBA 38801 Last edited by nail24fac; 02-05-2014 at 05:02 PM.. |
diz plaz is cwazy
Great to know. Dan wanted me to confirm because he tells me there is little info on these custom units for the 1200. Good thing is springs donīt need to be touched. I am getting new oil and seals all round..
No try, do or not do
do a search on R1200S suspension, and contrary to "popular" opinion the front shock is in need of upgrading if you are going to be riding in sport fashion, especially if you have the RT A-arm
HP2S springs R12S Ohlins Upgrade
2017 R1200GSW Rallye Shreddr Signature Model |
Hi all.
Whats the RT A-Arm about, I know of the shortening 10mm for the R11S, Haven,t heard of any change done to the 12S..? Jeremy |
diz plaz is cwazy
From what I've read rider weights above stock specs on the Ohlins drastically affect rebound on the 1200. I guess its not to smart a move for me to have the front modded without giving them a ride first....for now fresh seals and oil. P.S thanks for the links
R1200S a-arm swap
