brand new r11s owner
Found this forum and have been looking for any insights for my new to me r11s. It is a 2000 with 25k miles and just had the dealer 24k service. So I am good to go at the start nut want to make sure I keep up on everything.
First thing first... I need to figure out the rear lift situation. Looking at the Abba Lift, in conjunction with the Harbor Freight Wheel Chock.
Quick question about wheel mount and balancing with a single sided swing arm wheel... can your local Cycle Gear properly mount and balance them? I typically bring my wheel in after I remove it. Just need to figure that out. Let me know any tips and links that are good.
Thanks!!!!
Old 04-06-2014, 02:30 AM
ATA ATA is offline
Hi kevlarian,
I get my rear done at Car tyre place, the only what is specific they need to have thin spindle.
Most likely balancing will be fine (unless you'd touch them weights) as tyres usually perfectly balanced as how they are made, so no change to be expected.
Old 04-06-2014, 02:58 AM
R1100S
Nice bike. Whats the story with the mufflers?
Thanx
Dave
Old 04-06-2014, 03:12 AM
I hunt deer with my BMWs
Psychopath's Avatar
Thanx
Dave
They're HUGE!
2004 R1100SA (Street/Deer Spear)
2003 Suzuki SV650 (Track/Race CCS Expert#57)
2007 R1200S (SV650 replacement)
Old 04-06-2014, 05:59 AM
Registered Agitator
sgoodwin's Avatar
Welcome to the asylum. Yes, Cycle Gear can mount & balance your tires with no problem. they've done many of mine in the past when they used to have good prices. unfortunately that doesn't seem true anymore & I've gone back to mail order for the best prices. Be aware they have a policy of installing new valve stems every time they change tires so if you have angled or metal stems be sure to tell them not to change them, they took off my angled stems & I didn't notice right away, when I did they had disappeared & I was unable to get them back.
Old 04-06-2014, 07:12 AM
Exhaust are Two Brothers Titanium series.
Got to know about the tire situation. Is the an alternative to the Abba Superbike Stand that I could look into? Thanks again for advise.
Old 04-06-2014, 09:14 AM
diz plaz is cwazy
RIQUE's Avatar
You could always get a stock center stand. Cheaper and easy to use.
Life rewards action, He who is not afraid is safe!
A Zest for living requires a willingness to die!
BWM R1100S 2004 (fat girl) BMW S1000RR 2011(skinny
BMW R1200S 2007 (stingger) Honda CX500TC 1982 (turbo)
Old 04-06-2014, 09:37 AM
Interesting looking at the aftermarket paralever the rear looks jacked up but the angle of the bevel drive says not
Old 04-06-2014, 10:01 AM
tjs tjs is offline
centerstand
Wunderlich USA.
Old 04-06-2014, 01:11 PM
