Any plug-n-play non load dependent flasher units out there?
NO PLUG-N-PLAY RELAY NEEDED TO FIX FLASHER UNIT PROBLEMS. SEE AN UPDATED THREAD HERE.
Anyone found a non load dependent replacement flasher unit that will plug into the original flasher unit socket? I haven't opened up the flasher unit to look at the pin-out. Would it look something
Cory 01 R11S Last edited by Corkus; 04-21-2014 at 01:22 AM.. |
yes. tjs
This one will handle LEDs without the fast flash.
However , it will not self cancel ... you'll have to remember to cancel the turn signal yourself. Flasher Relay for BMW K1200LT | BMW Motorcycle Accessory Hornig |
Enthusiast
Post 25 of this thread here may be of help
![]() http://www.advrider.com/forums/showthread.php?t=218288&page=2 |
Enthusiast
No problem! Thank the guys on ADV!
I'm going to collect all the information I found into a thread on this topic because there is a lot of information and it is on different sites and threads. Thanks again.
Cory 01 R11S |
Enthusiast
You're quite welcome! It took me a few days to even find that one. Although, I have yet to find a flasher relay for the 12S...I want to believe the flasher is integrated into the big module. Luckily the LED drivers I have for my blinkers draw just enough current avoid the fast flasher action. (Well - I had one driver that still caused the issue, two out of three didn't).
Ben K. |
