unsafe at any speed
wswartzwel's Avatar
injector maintenance
the automotive service industry has equipment and chemicals that flush fuel injectors to remove deposits that develope over time. Is it neccessary(beneficial) to do this type of maintenance on the Beemer?
Bill Swartzwelder
Old 03-18-2004, 08:39 PM
CarlosT's Avatar
Cool
Run 1/4-1/2 bottle of Techron about 500 miles before your next oil change...that'll flush your orifices right clean
Old 03-20-2004, 11:50 AM
RoundelRider's Avatar
Send a message via Yahoo to RoundelRider
Techron is the only over the counter stuff that Ive seen actually work.
BG makes some excellent products, but can be hard to get ahold of since they dont sell to public.
John
John
'03 R1100S Prep RIP
Old 03-20-2004, 02:58 PM
steve abella's Avatar
my GS with ~50K was running a little ruff at Idle (may have gotten bad fuel so I replaced the plugs changedthe fuel filter
and ran the Techcron did not do the trick 1 bottle in 2 consecutive tanks
and it happened in this months MC news they mentioned Marvel mystery oil down the air intake which I did and was shocked at how much better it ran after that …..so I Put a can into the fuel but since it was now holding proper Idle I can't say it made much difference in the tank
,93 LT Hacked
98 RT
02 S ohlins/laser
06 HP2
84 GS/KTM
Old 03-20-2004, 07:14 PM
I have used marval top lube oil for 20 years. Good stuff. add it to your gas and engine oil. ( follow the cans instuctions)
Old 03-20-2004, 07:32 PM
roger albert's Avatar
Normally, you don't need to clean your injectors. I've avoided all the snake oils for better than 25 years and my motors all be fine. If you do have reason to believe your injectors are dirty, techron isn't bad. I prefer Berryman B12. I've yet to see a bad beemer injector, even back to '85 that ever had a problem not related to being left to sit multiple years.
99 R11S w/ BBP, InDuct, Öhlins, PVMs, Braking, SJ-Filter, ZTech, HIDs
D675 R90Cafe R60/2 M900 SV650-SS CBR150R XR125 & CRF175 Motards
OnRoad OffRoad Cycles, Austin, TX: BMW, Ital, Suspension, Electrics
Dealer for K-Tech, JRI, GP Suspension, Penske, Öhlins, RaceTech, Elka, Wilbers, IKON & Works
www.ororcycle.com
CMRA EXPERT #841
Various Formula 5, 6 & 7 championships 2006-2012
A3, Navigator,
Old 03-20-2004, 09:11 PM
EZ-RIDER's Avatar
I think it's more of a build up on the intake valves then dirty injectors.
From what I seen when I bore scope the engine a couple of years ago.
Dyno'd 104Hp 74.3 ft lbs torque at the rear wheel
1150 cylinders 12:1 pistons/ race cams, Lennies induct, Laser Boxercup II Exhaust, Ohlins shocks, Dymag Carbon Fiber Five Spoke wheels, Crossover tube removed, heads ported and polished Bigger valves installed intake and exhaust! SJ power filter, motoyoyo clamps , HID
Old 03-20-2004, 10:03 PM
unsafe at any speed
wswartzwel's Avatar
I was really referring to using something like a "motorvac" marketed through "Snap-on" that they use on cars. It disconnects the fuel system and runs the engine on a chemical that cleans all deposits from the engine. I don't believe in snake oil either, However I have used the General motors bottle of topend engine cleaner in older cars, with fantastic results. I was curious if anyone had experience using a motorvac system on the BMW.
http://www.auto-adv.com/MotorVac.htm
Bill Swartzwelder
Old 03-21-2004, 05:50 AM
