Go Back   Pelican Parts Technical BBS > 3- BMW Forums > BMW Technical Forums > BMW R1100S / R1200S Tech Forum
Tank is stripped.
I'll need to find a floor Jack and lift it up.
Would the whole process take more than 2 hours?
I'm only doing all this to eliminate welding the two tabs...is this worth it?
Old 02-24-2015, 06:58 AM
  Pelican Parts Technical Article Directory    Reply With Quote #21 (permalink)
unsafe at any speed
wswartzwel's Avatar
Here is a disassembly thread I did awhile back with some images that might help.
Neglected maintenance items to do this winter....
Bill Swartzwelder
2002 R1100S Prep/2006 BMW R1200GS
1969 BSA StarFire
Old 02-24-2015, 07:07 AM
  Pelican Parts Technical Article Directory    Reply With Quote #22 (permalink)
if you search for motoyoyo clamps, you'll find a section with a good description of how to get that front end apart, including the special tool you need to fab.
'04 R1100s. I changed a couple o' things.
Old 02-24-2015, 07:08 AM
  Pelican Parts Technical Article Directory    Reply With Quote #23 (permalink)
unsafe at any speed
wswartzwel's Avatar
And here is one that shows the ball joint in the top triple clamp that requires heat to remove the nut..
MotoYoyo Clamps Installed
Bill Swartzwelder
1969 BSA StarFire
Old 02-24-2015, 07:10 AM
  Pelican Parts Technical Article Directory    Reply With Quote #24 (permalink)
Gasteropod Rider
Meeni's Avatar
Here is another subject with the same discussion: dismantle the handlebar
Old 02-24-2015, 07:23 AM
  Pelican Parts Technical Article Directory    Reply With Quote #25 (permalink)
Thank you so much guys...
The way i see it, do you agree or are you implying that welding it is better than the hassle of replacing it?
Old 02-24-2015, 08:30 AM
  Pelican Parts Technical Article Directory    Reply With Quote #26 (permalink)
Now Available for Ordering:   101 Projects For Your BMW 3 Series 1982-2000  [more info]
Brent
doesnt matter don't weld it on the bike, take it off if you have it welded or replace it.
It is not a easy weld job I wouldn't consider doing it on the bike.
pretty easy decision get a quote on the weld vs used.
they are fairly easy to get out once the tank is off 20mins max
Old 02-24-2015, 03:09 PM
  Pelican Parts Technical Article Directory    Reply With Quote #27 (permalink)
Brent, i have access to a used one in perfect shape for $250. I also have a powerful impact wrench to perhaps undo that nut without heating. If it only takes 30 minutes to disassemble then I have no issues doing so, i thought it was real pain..
Old 02-24-2015, 03:37 PM
  Pelican Parts Technical Article Directory    Reply With Quote #28 (permalink)
unsafe at any speed
wswartzwel's Avatar
The stud will turn in the ball joint… You have to hold it with an allen wrench while loosening the nut… A big impact will just spin the nut and the threaded stud it screws onto.
You do not have to remove the ball joint from the top triple clamp as you are reinstalling the old clamp to the new frame.
Bill Swartzwelder
1969 BSA StarFire
Old 02-24-2015, 04:51 PM
  Pelican Parts Technical Article Directory    Reply With Quote #29 (permalink)
Is this a cap that needs to somehow come off for me to see the nut and the Allen head screw?
Old 02-24-2015, 06:58 PM
  Pelican Parts Technical Article Directory    Reply With Quote #30 (permalink)
Also,what's the trick to access this nut?
If i lift the bike on a Jack,would it be enough?
Old 02-24-2015, 07:07 PM
  Pelican Parts Technical Article Directory    Reply With Quote #31 (permalink)
Is this the nut to undo?
Not sure how i can both hold the Allen head screw while using the socket wrench on at the same time...I'm completely lost...
Old 02-24-2015, 07:10 PM
  Pelican Parts Technical Article Directory    Reply With Quote #32 (permalink)
Old 02-24-2015, 07:11 PM
  Pelican Parts Technical Article Directory    Reply With Quote #33 (permalink)
unsafe at any speed
wswartzwel's Avatar
That is why I said you needed to use a spark plug socket that has a hex on it for a wrench… you poke the allen wrench through the square hole, and turn the socket with a box end wrench. Or you can use a high offset box end wrench and an allen wrench...
Bill Swartzwelder
1969 BSA StarFire
Old 02-24-2015, 07:16 PM
  Pelican Parts Technical Article Directory    Reply With Quote #34 (permalink)
unsafe at any speed
wswartzwel's Avatar
That is the ball joint… it will remain in the triple clamp… it unscrews out the other side.. but you do not need to remove it for what you are doing.
Bill Swartzwelder
1969 BSA StarFire
Old 02-24-2015, 07:19 PM
  Pelican Parts Technical Article Directory    Reply With Quote #35 (permalink)
Now i understand.
Sucks that i broke the bmw logo on top...that's probably another $30 lol
  Pelican Parts Technical Article Directory    Reply With Quote #36 (permalink)
Bill, how do I remove the other nut?
Bike is on center stand right now, but when i lift the front, it still doesn't clear that nut.
Old 02-24-2015, 07:21 PM
  Pelican Parts Technical Article Directory    Reply With Quote #37 (permalink)
unsafe at any speed
wswartzwel's Avatar
This job is going to require some strength.. I see your hand in a cast in one of those images… would be good to let it heal before putting lots of force which is going to be required to get that nut from the underside of the frame loose.
Bill Swartzwelder
1969 BSA StarFire
  Pelican Parts Technical Article Directory    Reply With Quote #38 (permalink)
unsafe at any speed
wswartzwel's Avatar
When you take the shock loose it will move far enough to be out of the way.
Bill Swartzwelder
1969 BSA StarFire
Old 02-24-2015, 07:22 PM
  Pelican Parts Technical Article Directory    Reply With Quote #39 (permalink)
unsafe at any speed
wswartzwel's Avatar
Where are you located? there may be a member from the board close by willing to help.
Bill Swartzwelder
1969 BSA StarFire
Old 02-24-2015, 07:23 PM
  Pelican Parts Technical Article Directory    Reply With Quote #40 (permalink)
Copyright 2017 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
