BMWR502's Avatar
Worn splines through starter hole w/ video
So I did the spline inspection last night through the starter hole. As you can see in the video below, my input shaft is badly worn. For anyone that has been wanting to do this, but was unsure of what to look for I hope this helps.
remove starter
zip tie clutch
trans in 1st gear
rotate outer edge of the clutch disc with thin screwdriver
watch for the clutch disc hub rotating in unison with the input shaft
Spline Video
2018 R1200GS Rallye
2005 R1100S BCR
2003 R1100S BCR #73
1998 R1200C
1966 R50/2
Old 04-01-2015, 05:01 AM
Thanks for posting that...I have wondered what to look for, or how it should not look. Is that your 99 or your 03?
Lane
2005 Boxercup, 2013 R1200GS Rallye, 2011 Triumph 675 Daytona, Honda MB5, 2011 KTM300xc, 1975 Bultaco, 1992 Beta, 1972 Aermacchi
Old 04-01-2015, 05:21 AM
BMWR502's Avatar
2003 BCR w/ 36.5k miles
Looks like I may be holding onto the '99 for this riding season. Don't know how soon I'll have the funding to replace/rebuild the transmission.
2018 R1200GS Rallye
2005 R1100S BCR
2003 R1100S BCR #73
1998 R1200C
1966 R50/2
Old 04-01-2015, 05:43 AM
I see you
flatbutt's Avatar
Is it the opinion that the "slop" you saw there is too much? Thanks for the vid!
Old 04-01-2015, 07:46 AM
Instigator
The slop there is way too much.
Old 04-01-2015, 08:47 AM
Jozef Schumann's Avatar
I agree, that's far too much slop.
At the next oil service I'll pull my starter and see if there's enough componentry visible (due to the hub spacer) to video the difference. 5k miles so far, and of course - nothing to report.
J.S.
Old 04-01-2015, 10:15 AM
Hey OP, you mind if I link this to a few other sites? That's a damn good video.
Jim Moore
Jax, FL
'01 R1100S
'07 CBR600RR
Old 04-01-2015, 11:26 AM
BMWR502's Avatar
Of course! Be my guest. And while it is in the state it is in, I'd be happy to take more photos/videos if anyone has any requests.
2018 R1200GS Rallye
2005 R1100S BCR
2003 R1100S BCR #73
1998 R1200C
1966 R50/2
Old 04-01-2015, 12:18 PM
Registered Agitator
sgoodwin's Avatar
Failure is imminent, video it while doing a burn out so we can watch the final destruction. At least that way you're at home when it dies.
Old 04-01-2015, 05:31 PM
Instigator
Pull the transmission out, install modified clutch plate, move on. Total cost $300. No doom and gloom.
Old 04-01-2015, 05:54 PM
oneye's Avatar
Excellent video, many thanks. Scary.
99 R1100S
78D Yamaha XS Custom
65 Corsa Crown Corvair 400hp
Old 04-02-2015, 04:40 AM
ricky racer's Avatar
Old 04-02-2015, 08:50 AM
Originally Posted by ricky racer View Post
He's referring to this:
The plate on the right is fitted with a 6mm spacer he offers - which I and several others on the ADV forum have purchased and installed.
However. I also opted to replace my input shaft which was knackered as well. He feels the existing splines in conjunction with the previously unused portion is sufficient. Maybe so, maybe no. It would be a source of angst when I'm out there in the vast Mojave - now plagued with the knowledge of somewhat minimized spline area engagement with limited integrity. We shall see how well mine holds up when I pull the trans for an inspection - It would be interesting to compare against a machine with 'as scalloped' shaft.
J.S.
Old 04-02-2015, 09:38 AM
Great video, thanks for sharing. I suspect I might be doing the same thing on both of my boxers this weekend!
Old 04-03-2015, 03:33 AM
Instigator
J.S.
There is still a little bit of the input shaft visible. You have to have a good small flashlight.
Old 04-03-2015, 01:50 PM
sykospain
sykospain's Avatar
Send a message via Skype™ to sykospain
Clutch Splines
I'm one of those who bought a coupla those beautifully-made 6mm thick clutch friction disc hub spacers from Esmir Celebic on the ADVRider forum. Great solution to an inherent design problem that BMW has consistently failed to address with a "Technical Revision". Like asking Sachs AG to supply a plate with a longer hub.
Incidentally, I hope you don't mind Dan, but I've slightly tarted up your excellent little 25 second clutch spline wear investigation video to make it clearer to other readers on forums like UKGser, R1150R.net, etc.
https://youtu.be/dw6xP7a4EfM
AL in s.e. Spain
Old 04-11-2015, 09:35 AM
Are non of the replacement clutches from any manufacturer made with an improved longer splined hub..?
I find it amazing, and annoying that BMW haven't addressed this problem in any way, so we buy new expensive replacement parts and there still crap... WTF....
Old 04-12-2015, 11:44 PM
850dunstall's Avatar
tested today
so i pulled the starter , just had to see how it looked in there, with the clutch tied back, i could only get it to move about 1/8' from click to click. then the whole clutch turned, so with 52k km mines still good
claus
IBA, 04r1100s, 11f800st, 74norton, 05f650gs
auf Adlers Fluegeln getragen...
Old 04-25-2015, 06:12 PM
Instigator
I am not sure about your measuring, but if what you are saying is true, there is some wear in there.
Old 04-25-2015, 07:31 PM
Fish
op48no1's Avatar
I did this inspection today. There is no visible rust or metal shavings around the splines, but some rotational slop at the edge of the clutch disk. Does anyone know how much slop is "normal?"
Thanks.
-Henry
Old 05-17-2015, 06:09 PM
