Woe is my 2001 R1100s - Clutch Slave
Well I hate for this to be my inaugural post but here it is. I'm retired and bought a 2001 R1100s with 27k on it for my son. I figured I'd wrench on it a bit to get it ready for him and started out changing all the fluids, plugs and put on new brakes. So I got to bleeding the clutch slave and read that it might be loctited ( and it was) so I began to heat it with a heat gun. It remained stuck so I heated it a little more and low and behold it melted the hydraulic line where it enters the bleed fitting and the fitting came right off the line. yikes
Now I have no idea where or how I can reattach the fitting to the hydraulic line or if I have to buy a new line and dig all the way into the bike to get at the clutch slave cylinder to attach a new line.
You guys seem brilliant on these bikes so I thought I'd try and start here, begging for a little knowledge. Thx in advance.
Old 06-01-2015, 04:49 PM
You might need to replace the vent screw part #32 72 2 333 158
MAX BMW Motorcycles - BMW Parts & Technical Diagrams - R1100S (259S)
I've managed to strip the clutch and front brake caliper vent screws, getting the old one off is the worst part.
Hope this helps,
Doug
Doug
Minneapolis, MN
'01 R1100S ABS, Öhlins, Ztechnik exhaust, Corbin "Ol' Yeller"
'03 Yamaha TW200 "Skippy"
Old 06-01-2015, 05:37 PM
The end actually cam totally off the hydraulic line ( clutch vent line). So I either need to buy a whole new line for $125 or have to figure out how to reattach the end to that vent line. I've never tried to repair a hydraulic line fitting before and don't know what it takes. The $125 for 12 inches of hydraulic line and 2 fittings seems absurd.
Old 06-01-2015, 06:55 PM
Registered Agitator
sgoodwin's Avatar
Beemerboneyard, ibmwr.com, ebay, places to search for used goodies. No need to pay insane new prices if you can get it used & in good shape.
Old 06-01-2015, 07:04 PM
wiggledbits's Avatar
Send a message via AIM to wiggledbits
Worst case is have a local shop make a SS one for much less than OEM and have a regular bleed nipple at the end. Still would have to root around with the wheel off but...
Old 06-01-2015, 09:19 PM
Brent
if you cant find one I should have a spare.
Old 06-01-2015, 10:01 PM
I searched ebay and there are R1150 lines there but the part number for the R1100s ends in a 9 while the R1150 ends in a 5. So I'm not sure how different they are. Beemer Boneyard shows out of stock on the vent line. Checking the local independent shop to see if they'll make one up is also something I'll try today. Looks like I need to just remove the rear wheel and ? Top or bottom shock mount?
If anyone does have one they'd like to sell, I'd appreciate that. Thx
Old 06-02-2015, 06:22 AM
Got off the phone with BMW and there are none of those in the USA. There are R1150RT clutch vent lines in the country but those are $158. Even crazier and since the last 2 digits of the part number are different I'm not sure it would work.
Talked to the major independent shop in Seattle but he said they can't be repaired and he doesn't make up lines. Any ideas for what sort of shop I might go to to make up a line?
Old 06-02-2015, 09:44 AM
Google is your friend. In a big town like Seattle there has to be a shop that makes hydraulic lines. There is here in stump town 186 miles south.
Try here http://www.americanhose.com/inventory/index.php
or
http://www.rechargeman.com/Brakes.html
Old 06-02-2015, 09:53 AM
RBMann's Avatar
Quick search for R1100S clutch line. First hit was Spiegler for $68-
BeemerShop SPIEGLER CLUTCH LINE KIT // R1100S 98-05
Or eBay $40-
04 BMW R1100S R 1100 s ABS Clutch Line 4 | eBay
RBMann- The road is his workshop, and his trips are opportunities to do much needed repairs. -Bill S.
* 2000 S, color-Salmon 108K+ -sold
* '17 Africa Twin-totaled* '09 F650GS twin-sold
* '83 GPZ 550-gone to a newbie * '75 CB400F-retired to AZ.
Old 06-02-2015, 10:16 AM
Or eBay $40-
I don't think this is what he needs - these are the lines that run from master to slave. 4Motos needs the vent (bleed line).
Easiest - get a used one from Brentw1
Next: give Spiegler a call - I've always found them very helpful.
Good luck.
Old 06-02-2015, 10:42 AM
LeftCoast Peter's Avatar
Spiegler is great to deal with. Just be specific and you will get what you need. While at it maybe get new brake lines from them - and if you intend to use Rapid Dog bar risers get them longer.
2008 HP2S Sport Touring
2009 525 Beta RR
North Vancouver
Old 06-02-2015, 11:11 AM
You are correct. Those aren't the one I need. I need the clutch vent line. I'll PM Brent as well as try some local hydraulic related shops. thx.
Old 06-02-2015, 11:35 AM
RBMann's Avatar
Good luck.
Good point, now I understand. I kept wondering about vent line.
Here is the whole mess-
02 BMW R1100S R1100 R 1100 s Clutch Slave Cylinder | eBay
Old 06-02-2015, 12:11 PM
Instigator
I wonder if you could take the vent line off and install regular bleeder screw at the slave cylinder? Anybody tried it?
Old 06-02-2015, 12:56 PM
Thx for the Rechargeman reference. I called him and he works out of his house but said that even if he didn't have a new 6mm banjo fitting that he could likely reuse the old ones. I'm headed there tomorrow morning.
Thx also for the eBay reference. I don't know how I missed that when I looked. That's backup. I'll let you all know what happens with the Rechargeman fabrication tomorrow!
Old 06-02-2015, 04:17 PM
If you go custom just be sure the bleed end had a union that'll fit a bleed nipple.
Old 06-02-2015, 04:29 PM
I'll make sure to do that.thx
Old 06-02-2015, 06:15 PM
RBMann's Avatar
Both holes in the slave are threaded but nothing there for a bleeder to seal against.
Old 06-02-2015, 10:36 PM
Instigator
Old 06-03-2015, 03:02 AM
