Racing Start - R1200S
Is the R1200S's (stock) clutch and transmission strong enough to do moderate wheelspin starts for racing?
I.e. a Drag start. For example: hold 4500-5000; on green, release clutch smoothly and reasonably quickly (NOT dropping the clutch), feeding just enough throttle to hold, say, 4000 but not enough for a high wheelie; as front end comes down, full throttle to red line; shift.
Thanks,
Old 01-13-2016, 06:37 PM
GUS GUS is offline
Hi
Yes. The 1200s standard clutch can stand multiple race starts.
Gus
Old 01-13-2016, 06:44 PM
Deans BMW's Avatar
After several starts like that.........You will need to install a new clutch, recommend a Ceramic Clutch, San Jose BMW has and uses them.
Dean O
Copperhill,Tn
Founder, San Jose BMW
www.motorcyclistcafe.com
www.sjbmwracing.com
Old 01-14-2016, 01:56 AM
GUS GUS is offline
As stated above. A ceramic clutch would be a good idea if you are going to do this a lot, as in drag racing.
Old 01-14-2016, 03:51 AM
agree with those guys, and especially since your description sounds like you're using the correct technique.
abuse will tear things up. finesse lasts a bit longer.
go ceramic and treat it like it's still stock.
'04 R1100s. I changed a couple o' things.
Old 01-14-2016, 06:28 AM
Tags
clutch , racing , racing start , transmission , wheelie
