Gearbox drain plug leak...
NooB here.
New to me 2000 R1100S. 42k miles. Very well maintained.
Recently did a fly and ride from MD to WI.
Noticed a smell and found some moisture on the frame beneath the drain plug.
Got home and parked it. Came back a few days later to a silver dollar size stain on the floor directly beneath the drain plug. Wiped everything clean. A few days later, drip starting to form on drain plug. Wiped it clean. Took it out for a spin to get it up to temp. Put it up on the centerstand, cracked loose the plug and re-tightened. Came back this morning. Drip starting again.
Engine case looks sound. No obvious, to me, issues.
Suggestions?
Old 07-03-2016, 06:36 AM
I don't think there's going to be a way of removing the drain bolt without all the oil coming out.
Old 07-06-2016, 07:48 AM
No washer on this drain plug
Cheezewhiz,
I don't know if you know this or not but this drain plug for the gearbox doesn't have a sealing washer.
Before you drain the gearbox oil and try to reseal the drain plug, make absolutely sure the oil is coming from the plug. It could be leaking from somewhere else and collecting there.
Sometimes small oil leaks are hard to find.
Old 07-06-2016, 08:06 AM
The tightening torque specification is 55 nm, which is pretty tight.
Kent Christensen
Albuquerque
'12 R1200RT, '02 R1100S
'01 Boxster
Old 07-06-2016, 08:36 AM
Yep, I'm aware of the lack of crush washer.
I'm pretty sure it's from the gearbox. I've always found gearbox oil to have a distinct smell and the look of it is pretty clear. Just changed a few thousand miles ago by the PO. The rest of the engine is dry.
Thanks for the heads up on the torque.
Old 07-06-2016, 11:26 AM
Yes, the smell is added to discourage you from putting it in your engine. It's called 90 weight when it's really around 40 for the same reason.
Kent Christensen
Albuquerque
'01 Boxster
Old 07-07-2016, 07:15 AM
Brent
at the end of the day, it just needs to not leak
I would try a sealing gasket if you cant get it to seal,
unless of course as stated elsewhere here you have a leaking shaft seal etc
and it is just dripping off of the lowest point.
Old 07-07-2016, 07:32 AM
pwillikers's Avatar
Welcome Mr. Cheeze, or is it Mr. Whiz?
I had the same problem that I rectified by installing an aluminum crush washer. It solved the problem completely. I have no idea what BMW didn't include one from the outset. Here's the saga in excruciating detail. If you need a crush washer, PM me with your address and I'll mail you one.
Paul. '11 R1200RT, '09 Buell 1125cr, '08 Suzi SV650A, '00 Suzi SV650, '97 328i (with sticky ass tires - I love this car). And the bikes I used to own: '68 Bultaco 100, '69 Honda CL450, '71 Kawasaki Mach III, '71 OSSA Pioneer, '72 Honda MR175, '72 Benelli 250, '75 Yamaha RD350 (then college), '83 Honda VF750F (then kids),'96 MZ Skorpion, '99 R1100S, '01 SV650, '94 Honda VFR750F and '04 R1100S w/Öhlins an' stuff, most wrecked.
Old 07-07-2016, 10:34 AM
Hey Pwillikers, didja get my PM?
Old 07-11-2016, 12:07 PM
pwillikers's Avatar
yes. the eagle has taken flight.
Old 07-13-2016, 06:45 AM
