diz plaz is cwazy
Wobbly steering stabilizer
My stabilizer is all wobbly on the section that connects to the A arm of the bike. I have an older stabilizer that has the joint in good condition. Since the inside part has a safety pin I figure this joint is replaceable.
I want to ask if I must use a press or if I can just knock it out. I don't want to harm the little ball like part. ![]()
Life rewards action, He who is not afraid is safe! A Zest for living requires a willingness to die! -------------------------------------------------------- BWM R1100S 2004 (fat girl) BMW S1000RR 2011(skinny BMW R1200S 2007 (stingger) Honda CX500TC 1982 (turbo) |
Brent
its a hiem joint it should swivel and rotate it will need a press
beating bearings is never a good idea especially if you want to re use them |
diz plaz is cwazy
The swivel on my current stabilizer is too loose and over bumps it moves vertically hitting the A arm and making a racket. Old one is stiff as it should be.
Brent
sounds like you need a press and a proper sized bearing tool.
you might be able to get away with a C clamp or a Bench vise. you should be able to buy a new bearing, and it might be put together with loctite so you might need to heat it but not enough to damage the shaft seal |
diz plaz is cwazy
Got it out know I need to buy one. Can anybody recommend a vendor?
Is this the thing that's selling in the "parts for sale" section ?
Ohlins/Scotts Damper/5.5" Wheel/BCR Damper.. + |
I use Max BMW for some of my parts.
MAX BMW Motorcycles - BMW Parts & Technical Diagrams - R1100S (259S) ![]() |
Brent
this is off of the r1200s
why was it loose it doesnt look worn had the busshings moved out of position |
You might try riding without it for a bit to see if you really think you need one. Many just remove and never miss them.
Mike '07 BMW R1200S '99 Ducati 996 '09 Husky TE450 |
Oops, my error.
