Go Back   Pelican Parts Technical BBS > 2- BMW Forums > BMW Technical Forums > BMW R1100S / R1200S Tech Forum
RBMann's Avatar
I disagree with Lowndes. If you don't have ABS then it is much less work to hinge up the rear subframe on the upper mounting bolts. It saves time leaving the all the electric wiring in place.
RBMann- The road is his workshop, and his trips are opportunities to do much needed repairs. -Bill S.
* 2000 S, color-Salmon 100K+ * '09 F650GS twin
* '83 GPZ 550-gone to a newbie * '75 CB400F-retired to AZ.
Old 04-18-2017, 09:00 AM
RBMann's Avatar
Dana-
This might be a better pic of the stand.
Old 04-18-2017, 09:05 AM
World's Slowest Wrench
Dana in Philly's Avatar
Mine is a non-ABS bike.
Dana in Philly
2000 Mandarin R1100S Garage Queen
Old 04-18-2017, 02:08 PM
BMWR502's Avatar
Here is a thread I started last year. Includes a good bit of info and photos.
Worn Splines Thread
2005 R1100S BCR
2003 R1100S BCR #73
1998 R1200C
1968 R60/2
1966 R50/2
Old 04-18-2017, 03:00 PM
encantado
darkonaut's Avatar
BMWR502's thread is great. the "dr. splinelube" procedure also takes off the frame and swingarm as one unit:
Dr. Splinelube
GSAddict is cele0001 here. if you read about the causes of spline failure you may or may not decide his spacer is worth it to you. i expect to have to break the bike in half for something else before the splines go so i didn't add one
remember that now. -dav
it’s what makes life interesting, finding the balance between cigarettes and tofu. –gwenyth
Old 04-18-2017, 03:09 PM
unsafe at any speed
wswartzwel's Avatar
Darkonaut, I am surprised you found Repoe3's old thread. His bike is currently in Colorado somewhere. he sold it a year or so ago.
Bill Swartzwelder
2002 R1100S Prep/2006 BMW R1200GS
1969 BSA StarFire
Old 04-18-2017, 05:10 PM
RBMann's Avatar
You can do it either way. I have only done it five time so I am not an expert. Since I work alone, having more small pieces makes it easier to put back together. Trying to get the frame-swingarm unit aligned and back on can be tough. With the frame up you already have two mounting points and just hinge it down into place.
Old 04-18-2017, 09:41 PM
Thanks for the thread links, guys.
Rain expected Sunday here. Good day to prepare some space in the garage, and move the bike into position for the tear down.
Dana in Philly
Old 04-19-2017, 04:34 AM
"I disagree with Lowndes. If you don't have ABS then it is much less work to hinge up the rear subframe on the upper mounting bolts. It saves time leaving the all the electric wiring in place."
Hey, RBMann,
I did mine the hard way, piece by piece starting at the license plate. Well, not quite. But I wouldn't recommend that way, it was a lot of bits to keep track of, lots of head scratching on re-assembly. I did want to re-do and inspect the para-lever bearings and re-torque them per Chris Harris (10-12NM??), plus I was considering replacing the pinion seal but demurred on that.
Question - in your pic, where did the swing arm go?? The "side swing" that Chris Harris showed still had the tranny-frame-swingarm-wheel together. Is the "up-swing" vs. "side-swing" dependent on the ABS piping?? Just asking in case I gotta go back in one day.
Old 04-19-2017, 03:47 PM
To Whom It May Concern - NOT the easiest or quickest route:
Old 04-19-2017, 03:52 PM
RBMann's Avatar
The swing arm comes off before you hinge up.
I am pretty sure you need to remove the sub-frame because the ABS hardline to the pump won't let you hinge up.
Old 04-19-2017, 10:10 PM
Brent
I usually remove the swing arm its just easier to put it back together and get
the splines snapped on with it apart. and synced.
and tip the frame up.
Old 04-20-2017, 12:15 AM
Got the operating theater set up this morning. Next step: building an RBMann-style stand.
Dana in Philly
Old 04-22-2017, 09:32 AM
Stand mocked up. Waiting for my partner to get back from Cape May with the drill, so I can screw it together.
Dana in Philly
Old 04-22-2017, 11:22 AM
Now, put the whole thing on a lift. Trust me on this.
Old 04-22-2017, 04:56 PM
RBMann's Avatar
Dana, if you don't have a manual then just check off these steps as you go.
Old 04-22-2017, 09:42 PM
Thanks RBMann, for all that scanning. Appreciate it.
Dana in Philly
Old 04-23-2017, 02:58 AM
Here is a link for a PDF R1100s service manual.
OK5BMW_R1100S_Repair_Manual
Old 04-23-2017, 03:59 AM
Thanks twitchy. I've downloaded it.
No Clymer manual for this model, it seems, from my googling.
Dana in Philly
Old 04-23-2017, 04:13 AM
RBMann, re the pages you scanned:
I wasn't planning to disassemble the driveshaft and final drive, but rather, was planning to disconnect and swing the driveline (from the transmission back to the rear wheel) out to the right, a la Chris Harris' video here:
https://youtu.be/-PdVvxMwz_A
That's doable for the R1100S, correct?
Dana in Philly
Old 04-23-2017, 04:20 AM
Copyright 2018 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
