Jon
brake reservoir hose I.D.
they want too much for a piece of hose at the dealer, anyone know what size i.d. hose I need for the rear brake reservoir to master cylinder? And where to get it?
unsafe at any speed
It has to be hose that is resistant to brake fluid. Fuel line and oil cooler line hose will swell and leak brake fluid all over your paint... Make sure you get the right hose or it will cost you more than the BMW part in the long run.
Bill Swartzwelder 2002 R1100S Prep/ 2024 Tenere 700 |
The hose in addition to being resistant to brake fluid must be a high pressure hose. Check ebay for a replacement.
Jon
Registered Agitator
It isn't, just flows from the reservoir to master cylinder. It is nice to have the proper hose bend though so it doesn't kink up on you.
