04 R1100S
Center stands diagrams, Pics....
Hi Group,
Any detail photos, diagrams available to show how each part of a Center Stand attaches to an 04 R1100S? Thanks, Slick.... ![]() |
2004 R1100S |
2004 R1100S |
04 R1100S
Thanks much guys!
Slick.... |
Spring item number 8 fits inside Spring item number 7.
The two springs are attached to shackle item number 9.
2004 R1100S |
Talk Less, Say More
Location: Moab Utah. Home of wierd red & orange radioactive stuff... And 1 billion tourists.
Hopefully the center stand will fit and work OK on your bike. BMW purposely didn't put the center stand on certain configurations as the suspension sat higher and it was unstable.
cRaIg CaRr 2000 Dyna FXDX, 2001 Sportster Sport, 2000 R1100S,2007 R1200S,2015 rNineT,2023 F850GS,2023 R1250RS, 2017 Triumph T100, 2019 Jeep Rubicon, 2005 Jeep Sport, 2001 Corvette, 1978 Porsche 928. 2001 GMC Sierra 2500HD, 22 pairs of shoes. 24 bottles of beer. |
04 R1100S
Thanks for that info ckcarr.....
04 R1100S
RE: Center Stand Mounts
Hi Guys,
Can I get a little help here. It looks like I have to heat this thing up to get it out? The new (used) center stand came with its own (pivots/Bushings) so looks like this one on the bike needs to be removed. Should I be heating this thing up to get it to Move or Turn out? There is a bolt size difference...so... See Pic... Thanks, Hans. Aka Slick.. ![]() ![]() |
04 R1100S
Just incase some else needs to know this. These 'Nuts' can be knocked out with a ball peen hammer and the long or deep half inch socket.
Done! Slick.... Last edited by R1100S-Slick; 07-25-2017 at 08:56 AM.. |
04 R1100S
Quick follow up: Photos!
Note I have a shorter Torque arm so my rear wheel still makes light contact with the floor even though I am on the center stand. Either a 2x12 or this device will get the wheels off the ground for servicing. ![]() Slick... ![]() |
I just installed the center stand on my bike, thought I'd share a few tips:
Item (11) of which there are two, thread into the rear frame in an upward direction. When the bike is on the center stand the steel frame of the stand sits on the steel heads of these bolts. This will raise the bike up a bit. Without these bolts my rear tire sat on the ground, as soon as I installed them the rear tire is lifted. It DOES position the bike closer to where the bike pushes forward off the center stand, so don't park nose down hill on the center stand. I think if you have the shorter arm, your could put one or two flat washers under the bolt head and would make the stand a little taller, but also easier to get off the stand. The sleeves (2) go into the aluminum frame, and if your bike has had a stand, these are probably already in place and you don't have to buy them. Hint, I have 2 if someone needs them. The orings (4) are hard to get on, but a little wheel bearing grease and the slip into the sleeves. The engineer in me says those sleeves keep the inserts from wearing the frame. The springs are a pain to get on. I spent an hour trying all kinds of ways to get both springs on at a time, launching them all over the garage. I finally used a brake spring tool to put the big spring on, then put the small spring inside the large spring and was able to use a screwdriver to pull the small spring The rubber bumper (3) rests against the cat converter and keeps the stand from banging on the lower arm. if you have a cat delete pipe you'll have issues.
2001 RS1100S Light. Black on Black w/carbon fiber bits. |
