unsafe at any speed
Glad you are back rolling Erric, I am back home now, and looking at the tech manual for the pic you were referring to on the phone. Not much to go by.... I found this one, which doesn't really give a good perspective.
The second image is correct. BTW where did you get my number??? Flattbutts wall??? ![]() ![]() ![]() This picture from the parts fiche is correct. ![]()
Bill Swartzwelder 2002 R1100S Prep/2006 BMW R1200GS 1969 BSA StarFire Last edited by wswartzwel; 07-08-2006 at 09:55 PM.. |
Yup, those were my exact two dilemma-inducing, photo diagrams.
![]() You'd be surprised what's written on his walls. ![]() ![]()
aka Rev Z-Man -- click http://www.bmwforums.net for a good time. - 2002 BMW R1150GS - Graphitan - 1998 KTM 300 EXC - ORANGE! - 1995 Triumph Daytona 900 (For Sale!) - 1985/86 GSX-R 750 (Track bike in progress) |
unsafe at any speed
No bother at all. Glad to help.
Bill Swartzwelder 2002 R1100S Prep/2006 BMW R1200GS 1969 BSA StarFire |
How much play in these final drive to Paralever bearings is too much when grabbing the rear wheel at 6 & 9?
I have the "tick-tock" as someone eloquently described it, but since these are tapered bearings, I would expect some play. Even when adjusting front wheel bearings on my F-150 pick-em-up truck to spec there is some play. How do you know when it is time to adjust/replace these babies? -Jeff
BMW: 2016 R1200RS, 2000 R1100S, 1975 R90S Ducati: 2008 S2R1000, 1998 900 Supersport Final Edition Honda: 1998 CBR1100XX Super Blackbird Norton: 1974 Commando 850 Triumph: 2020 Speed Triple, 1971 T120R Bonneville |
If you feel play, _any_, then they are loose.
99 R11S w/ BBP, InDuct, Öhlins, PVMs, Braking, SJ-Filter, ZTech, HIDs D675 R90Cafe R60/2 M900 SV650-SS CBR150R XR125 & CRF175 Motards OnRoad OffRoad Cycles, Austin, TX: BMW, Ital, Suspension, Electrics Dealer for K-Tech, JRI, GP Suspension, Penske, Öhlins, RaceTech, Elka, Wilbers, IKON & Works www.ororcycle.com CMRA EXPERT #841 Various Formula 5, 6 & 7 championships 2006-2012 A3, Navigator, |
Yes, the manual is very adamant about ZERO PLAY.
Biggest Member
as is my wife...
'99 R1100SA, ;06 DR650, '84 R100RT |
pretty odd size/aspect-ratio.
No luck on alternate sources so far, despite a lot of digging.
I should have verified the size on the outer race, but is the size listed on the fiche correct and enough to search on? (10x32x17)?
(I also performed the Cam Chain Tensioner Update ... MAN, what a difference in that start-up clack, GONE! ![]()
'99 R1100S DDP of course I was born a rightie but now I'm a leftie. |
Yes I did! I confused the guys (and gals) at CCBMW yet again with that one!
![]() ![]() BTW, I was asked this my the bearing guys, anyone have an answer for it? "What type of needle bearing? Do needles ride directly on shaft? Is the outside of bearing stamped steel? ( Drawn cup)> Drawn cup is normal for most japanese bikes. "
unsafe at any speed
Bill Swartzwelder 2002 R1100S Prep/2006 BMW R1200GS 1969 BSA StarFire Last edited by wswartzwel; 07-11-2006 at 08:55 AM.. |
I'll see if that helps!
Living on borrowed time!
Do any of youze guyz remember that there's a guy at rubber chicken racing that makes these out of oillite bronze?
Way more load tolerance. When (that's the bad part, there WILL be a 'when' AGAIN on a shaft-driv e bike) I do this again I'm going oillite bronze bush. A better design for this particular application than a tapered roller.
Better a has-been than a wanna-be 'I am John Andrew Moffett of the Clan Moffat and by god I live, love, seek, fail, grieve and die as I so choose and I call no man master save me'. |
unsafe at any speed
How does bronze compare in rolling resistance, under load? Will it deform under pressure? The pivot bearings take a pretty good pounding with every bump.
Also the bearings are tapered for lateral as well as axial loading. How are the bronze bushing made... Tapered as well?
Bill Swartzwelder 2002 R1100S Prep/2006 BMW R1200GS 1969 BSA StarFire Last edited by wswartzwel; 07-11-2006 at 10:00 AM.. |
Yes, they're tapered like the original design, just oillite bronze.
I've had severeal bearing folks tell me that tapered roller bearings in this particular usage is a misapplication of technology as the tapered roller bearing is designed for a continual rotating action with loading thru the 'roll center' of the bearing roller. the swingarm moves only a small amount, the same wear surface is exposed to load with no rotation of the rollers into a new position, thus just a few rollers take the major brunt of a straight-thrust impact. made sense to me.
unsafe at any speed
Hmm need to add to the periodic maintenance, disassemble and rotate my pivot bearings every 3,000 miles... ![]() Found THIS online, but am hesitant to try a substitute due to the catastrophic results if these bearings were to let go. Tends to muck up the rear of the bike from the pics I have seen online. would like to find out more about the "oilites" though Jony, is there a website???
Bill Swartzwelder 2002 R1100S Prep/2006 BMW R1200GS 1969 BSA StarFire Last edited by wswartzwel; 07-11-2006 at 10:51 AM.. |
this is the dude, post him directly...
http://www.rubberchickenracinggarage.com/
Thread Tools | |
Rate This Thread | |
