Go Back   Pelican Parts Technical BBS > 2- BMW Forums > BMW Technical Forums > BMW R1100S / R1200S Tech Forum
04 R1100S
R1100S-Slick's Avatar
AF XIeD?
Hi Guys,
I'm asking for some help here. I don't see the O2 Sensor connectors under the tank. I have lifted it and looked at the Haynes & Clymer Books for reference, but no pic of the connectors or which wire is which under the tank.. any one here have that info handy?
Really want to give this device a go...
Got my Hardware from KnightRider.com.
Thanks,
Slick
Old 08-17-2017, 07:25 AM
Start at the 02 sensor, trace the wire up to the connector and there shouldn't be any mystery. It should be zip-tied to the frame on the right side of the bike.
Old 08-17-2017, 07:30 AM
The URL is - Welcome to Nightrider.com Performance Products - Modern Engineering - Old School Service
Look for a plug that looks like this, it's the only one that'll look like this -
2004 R1100S
Old 08-17-2017, 08:10 AM
It's tied to the frame on the right side about mid-tank. You need to lift the tank quite a bit to get to it, as I remember.
The thing works pretty well once it's installed and set.
Old 08-17-2017, 12:14 PM
04 R1100S
Thanks You Guys! I just couldn't recognize it! Ill try again...
Old 08-17-2017, 01:02 PM
Hey, Slick,
Pay heed to the warnings about the fragile plastic "keepers" on the connector. VERY EASY to break.
You will not notice an immediate improvement, just a gradual adjustment over 2-3 tanks of gas. It will start easier, not so cold natured. Roll on power is MUCH improved. Stalling at stop lights is gone. EASY to start off in 1st. Runs like it's supposed to run. Runs COOLER, too. Mileage is about the same except that you are having much more fun now.
Techron concentrate (from Wally World) helps. EV-14 injectors make a difference, too.
I'm a very happy 3 time customer, r1100s, r100rt, k1200rs. First thing I do is order can AF-Xied.
Old 08-17-2017, 03:27 PM
Brent
lots of opinions on techron, but one issue with it is as it hits the back of the valves
it leaves depsits, some engine designs are worse than others ,
Old 08-17-2017, 06:18 PM
Copyright 2018 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
