Go Back   Pelican Parts Forums > 2- BMW Forums > BMW Technical Forums > BMW R1100S / R1200S Tech Forum
Transmission Drain Plug Tool
Just bought a 2015 VW Beetle, and was researching the DSG transmission fluid change and ran across this tool. Thought you guys might find it of use since it has a 14mm hex as the R1100S does.
"https://www.*********.com/b-schwaben-parts/14-17mm-service-wrench/ecst0071kt/"
2001 RS1100S Light. Black on Black w/carbon fiber bits.
Old 09-15-2017, 04:10 PM
Registered Agitator
sgoodwin's Avatar
Don't think that link's gonna work.
Old 09-15-2017, 04:16 PM
yeah apparently Pelican is smart enough to block anyone from link a competitor's website. Like ECS Tuning...
Old 09-15-2017, 04:26 PM
Don Ro's Avatar
https://www.turnermotorsport.com/p-361567-schwaben-bmw-1417mm-service-wrench/
Don
"It's a blessed moment to realize that you are the word "It" in the sentence, "It is raining."
- - Don R. 1994, an excerpt from My Ass From a Hole in the Ground - A Comparative View
Old 09-15-2017, 09:43 PM
I'd doubt there will be clearance for that tool.
I have the BMW tool, and clearance is gone before the plug is totally out. Last turns with big channellock pliers.
Kent Christensen
Albuquerque
'12 R1200RT, '02 R1100S, '84 R80G/S
'01 Boxster
Old 09-25-2017, 04:05 PM
Not sure, I used the 14mm bit out of a harbor freight set, and a 14mm gear wrench. it is a pretty thing, and I have tool boxes full of pretty Park bicycle tools.
Old 09-25-2017, 04:42 PM
I'll just leave this here: R1100S & R1200C Transmission Drain Wrench
disclaimer: I invented this, sold it on the forum for a while and now supply Beemerboneyard. However, I feel it's by far the best tool readily available - you can put a breaker bar on it, and to replace put a torque wrench at 90 degrees to ensure you're getting it torqued to spec. It's only a little bit more expensive than the previously linked wrench, and has big benefits (to me, at least). Plus, guaranteed clearance to the exhaust.
Let me know of any questions or suggestions!
Old 09-25-2017, 06:20 PM
Registered Agitator
sgoodwin's Avatar
I own one of the originals from here, works great & have the angle conversion chart to figure torque values.
Torque Wrench Adapter - Extension Indicated Torque Calculator | Engineers Edge | www.engineersedge.com
Old 09-26-2017, 03:42 AM
Originally Posted by iminspaaace View Post
I'll just leave this here: [url=http://www.beemerboneyard.com/r11sr12ctool.html]R1100S & R1200C Transmission Drain Wrench
I have one of these and it is a well made sturdy tool that makes transmission oil changes almost pleasurable.
'04 R1100S BCR, '07 F800S (sold), '04 R1100S (totaled), '15 Thruxton (sold),'90 NT650 (sold), '86 SRX6 (sold - worse decision I ever made)
Old 09-26-2017, 04:08 PM
I just bought the correct size allen wrench and sawed off one end enough so it fit.
Old 09-26-2017, 05:09 PM
I tried that as well, but that drain plug wouldn't budge (at least the first time I changed fluid). Perhaps the PO over torqued - should be 55 Nm. Iminspaaace's tool allowed me to put a good sized breaker bar on it and then tighten properly.
Old 09-27-2017, 03:07 AM
Wow, that means a lot to me! Thanks for the compliment.
Old 09-27-2017, 06:36 PM
sɹǝʇndɯoɔ sǝʇɐɥ
BikerMiker's Avatar
I have one of these and it is a well made sturdy tool that makes transmission oil changes most pleasurable.
I fixed it so I could laugh.
Mike
'83 R100RS
'07 R1200S
'07 DRZ-400s
Old 09-27-2017, 07:02 PM
GS ADDICT's Avatar
Or you can make up your own for under $1
If you need your Hall Sensor plate rewired - PM me.
Old 10-14-2017, 07:13 AM
bobby11's Avatar
Thanks GSaddict. This worked like a charm. Home Depot has coupling nuts that are an inch long so didn't even have to cut one.
Old 10-25-2017, 10:42 AM
tm1100s's Avatar
This....14mm both ends
or this...
https://www.ebay.com/itm/VINTAGE-MERCEDES-BENZ-DRAIN-PLUG-WRENCH-1957-63-14MM-HEX-FROM-THE-TOOL-KIT/292297492027?hash=item440e49c63b:g:u5oAAOSwsBtZ5oS 7&vxp=mtr
One piece, compact, good quality and works.
tm
(R12, R11, R1) + 00 then S, S, /7
Old 10-25-2017, 01:02 PM
