2003 r1100sa ABS pump failure 2x
2003 r1100sa - ABS failure - pump bad 2x in 4,000 miles. Bike had low mileage from the first replacement at 23K. Now has 27K, although has been 6 years. What the heck is this !! Dealer wants $3500 for a new pump installed. Bike is not worth that to me, after the first pump install I do not want to put that kind of bucks into it. I asked if the dealer would do a by pass of the ABS, was told it would cost even more. Plenty of extras, motor runs strong. Original owner.
ABS lights read out low level in ABS pump. Dealer says fault readouts point to pump failure.
By pass? Part out? sell as is?
Anyone else have this issue?
Thanks for the feedback....
2003 BMW R1100SA
2002 BMW R1150RT
1986 K75 (sold)
1984 Porsche 911 Carrera
2007 Toyota Tundra 4x4
Old 11-07-2017, 02:31 PM
That's bad luck on the pump - no way it should fail that fast. Did you do regular flushes over the 6 years?
If you still like the bike, I'd do an ABSectomy. I've done two ('04s) and they're pretty easy - lot's of DIY help on the forum. Total cost would be for a set of new lines from Galfer or Spiegler for a couple hundred dollars.
'04 R1100S BCR, '07 F800S (sold), '04 R1100S (totaled), '15 Thruxton (sold),'90 NT650 (sold), '86 SRX6 (sold - worse decision I ever made)
Old 11-07-2017, 04:23 PM
Registered Agitator
sgoodwin's Avatar
Remove it, there's great brakes under all that mush. Search the threads for ABS removal on your year bike as you'll have to leave the computer to run your brake light & speedometer. Fortunately I have A '99 & it is much simpler, only need to remove it & run lines from masters to wheel cylinders. It will also take a fair amount of weight away up high, I noticed it immediately on the first ride as the bike turned in quicker.
Will have to search further. Dealer is telling me the inspection will not pass if removed as the bike came with iABS. I also have an iABS failure on my 2002 r1150rt, same iABS module. It is original and fluid was flushed two years ago. Both bikes, both have iABS pumps according to dealership. I did not do regular flushes on the r1100s replacement pump as ofter as I should have. I have read that the iABS units are a little more difficult then others to replace. You know anyone in the Philly area ?
2003 BMW R1100SA
2002 BMW R1150RT
1986 K75 (sold)
Old 11-07-2017, 04:31 PM
Registered Agitator
sgoodwin's Avatar
I would check before I believe the dealer about inspection. ABS was never required on bikes.
Old 11-07-2017, 04:40 PM
I am sure that not ALL inspection locations would know, or even notice. Not a problem, was just mentioning they wanted nothing to do with removing my ABS unit. Asked directly. What is killing me is I have two bikes, both with ABS failure. This second one is unacceptable, would like to remove I guess.
2003 BMW R1100SA
2002 BMW R1150RT
1986 K75 (sold)
Old 11-07-2017, 04:45 PM
tjs tjs is offline
Tom Cutter . Rubber Chicken Racing. 25 mi. North of Philly. on I-95. One of the best Independent BMW Techs around. I would check with him. Maybe your I-ABS pump is still good. You mentioned somewhere it was low on fluid. They need regular service intervals. Also updated braided brake lines are a good idea. The I-ABS brake flush, pump included is quite a process for some. Also some BMW Dealerships. Don't want to mess with old bikes or are limited to servicing current models.
2cnts from tjs
Old 11-07-2017, 07:19 PM
On Tom's waiting list.......
2003 BMW R1100SA
2002 BMW R1150RT
1986 K75 (sold)
Old 11-09-2017, 05:31 AM
bobby11's Avatar
Bypassing the iabs is not expensive. I did it on a k12rs with iabs (absIII) and it was easy. Not sure it's required to pass inspection. Although abs isn't required for all motorcycles it is standard equipment on that bike. Remember that the abs lights will continue to flash so you might have to do something about that for the inspection.
Old 11-09-2017, 08:00 AM
I remedied that by pulling the bulb
Old 11-09-2017, 09:25 AM
bobby11's Avatar
Sounds good. Remember if you sell the bike put the bulb back in and disclose the non functional abs in the buy/sell. The attorneys here may say that alone won't eliminate one's liability. Dunno.
Old 11-09-2017, 01:48 PM
Agreed - I'd never sell without full disclosure.
Old 11-09-2017, 02:06 PM
EZ-RIDER's Avatar
Bmw ABS unit rebuild
It's called modular master. Type that into google and it will come up.
http://www.modulemaster.com/
Module Master Rebuilds BMW ABS Pump Modules | Adventure Rider
Old 12-04-2017, 05:50 AM
tjs tjs is offline
is not currently available for what Module Master calls ABS 111. Or power integral ABS. Been that way for years. tjs
Old 12-04-2017, 06:54 AM
tjs tjs is offline
A company in Germany does rebuilds to Integral ABS units. address is www.rhelectronics.de
Old 12-04-2017, 07:33 AM
I canít help much as iíve managed to avoid ABS like the plagued(until my latest 2) I know their are fans out there but iím Not one of the them.
I waited nearly 2 years trying to buy a K1200r Sport without it and finally had to give in and put up with it sure enough the ABS unit went belly but later versions!! well later than 07 have come on by some margin.
When the one on my K stopped working guy at the shops says ĎBeen down a pot hole?) and sure enough I had but iím Reliably informed later stuff is much better so iíd Be looking for a modern day rebuild its come on some in the last 15 years.
XR1000
K1200r Sport
XT660
Tiger 955
R1100s
Old 12-04-2017, 09:18 AM
+1 they rebuilt mine, I'm happy...$300+
2001 R1150S - project bike
2004 R1150SR - Project Touring Bike
2005 Honda RC51 SP-2 project bike
2014 Ducati Hyperstrada - fun touring bike
Old 12-04-2017, 02:51 PM
tjs tjs is offline
Module Masters Website says: IABS (also known as ABS111 or servo-assisted integrated ABS) is BMW's third generation of motorcycle ABS. goes on to say. UNDER DEVELOPMENT (The Rebuild Process) (Not Currently Available) tjs
Old 12-04-2017, 04:33 PM
If you have not already done so, R&R the factory brake lines with SS, either Galfer of Spiegler. Not uncommon for stock lines to rupture internally, causing what appears to be an ABS failure.
Dealers can't/won't remove an ABS system due to liability issues. Not such a tough thing to do on your own, if it comes to that.
"Wow I'm an idiot, thanks bikerfish!"
Harleys are like opinions, every a-hole's got one!
2001 R11S "lite", with a few mods.
2009 F800GS. has a better saddle. and other stuff. (sold)
2016 R12GSW 3Black. wow.
Old 12-25-2017, 10:38 AM
r1100sp's Avatar
Ditto. I performed the "surgery" on my '02 many years ago and am very pleased for a number of reasons. As tic suggests, you should remove the ABS indicator bulb (and the small blue relay in the right side relay/fuse pod) and all will work just fine.
If your energetic and can weld aluminum, you can take advantage of the additional space the ABS pump occupied and enlarge the stock aluminum tank at the same time. I fabbed a tank "extension" and my new capacity is about 6.3 gallons. I posted the process but I fear the photos are no longer visible as I have not renewed my Photobucket account...which used to be free! Is the "cloud" a free solution when I get a new smart phone? (sorry for the off-topic question. A PM would be greatly appreciated.)
Old 12-29-2017, 02:55 PM
