Go Back   Pelican Parts Technical BBS > 2- BMW Forums > BMW Technical Forums > BMW R1100S / R1200S Tech Forum
Center stand bump stop
Can anyone tell me or show me what you're doing for a bump stop when the cat is removed on 99 R1100S ? Thanks
Old 11-13-2017, 03:15 PM
  Pelican Parts Technical Article Directory    Reply With Quote #1 (permalink)
I went the other way, installed the cat and the center stand. I've seen pictures of a few cat delete pipes that had a rod that went side to side and had a triangle piece that sticks down for the rubber bumper.
I thought about using a stainless hose clamp to mount a Z bracket directly to the cat delete pipe for the bumper to rest on. would look funny hanging down when bike is on center stand, but in motion, who cares.
2001 RS1100S Light. Black on Black w/carbon fiber bits.
Old 11-13-2017, 05:29 PM
  Pelican Parts Technical Article Directory    Reply With Quote #2 (permalink)
Thanks, that's what I was thinking. Fabricate a bracket to go from side to side. Powder coat it black to blend in with the pipe and frame.
Old 11-13-2017, 06:35 PM
  Pelican Parts Technical Article Directory    Reply With Quote #3 (permalink)
BigDav's Avatar
This thread might help
Old 11-14-2017, 05:34 AM
  Pelican Parts Technical Article Directory    Reply With Quote #4 (permalink)
Here's pics of what I did. I drilled & tapped the cat mounting tab (similar to thread referenced above). I did both sides, but one side will work just fine. Easy to adjust so that center stand is level to the ground when up without hitting the torque arm.
BTW - I like the paint job.
'04 R1100S BCR, '07 F800S (sold), '04 R1100S (totaled), '15 Thruxton (sold),'90 NT650 (sold), '86 SRX6 (sold - worse decision I ever made)
Old 11-14-2017, 10:33 AM
  Pelican Parts Technical Article Directory    Reply With Quote #5 (permalink)
Tic105, looks very clean and professional. Thanks, I'll seek to do it like that.
Old 11-14-2017, 02:54 PM
  Pelican Parts Technical Article Directory    Reply With Quote #6 (permalink)
McMaster-Carr sells those bump stops. Work like a charm.
"Wow I'm an idiot, thanks bikerfish!"
Harleys are like opinions, every a-hole's got one!
2001 R11S "lite", with a few mods.
2009 F800GS. has a better saddle. and other stuff. (sold)
2016 R12GSW 3Black. wow.
Old 11-19-2017, 08:10 AM
  Pelican Parts Technical Article Directory    Reply With Quote #7 (permalink)
r1100sp's Avatar
Yes, very clean install, tic. Are the metal parts of your assembly (threaded stud, washers and nut) stainless steel? Just curious; as that area of the bike is subject to all kinds of road grime, water, etc.
Old 11-19-2017, 11:58 AM
  Pelican Parts Technical Article Directory    Reply With Quote #8 (permalink)
Yes, all stainless bolts & washers. I tried to find the right bump stops on McMaster Carr but ended up finding some rubber shock pieces at a local auto parts store and used those.
Old 11-19-2017, 02:25 PM
  Pelican Parts Technical Article Directory    Reply With Quote #9 (permalink)
https://www.mcmaster.com/#catalog/123/3853/=1abug6d
Old 11-19-2017, 03:28 PM
  Pelican Parts Technical Article Directory    Reply With Quote #10 (permalink)
Copyright 2017 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
