-   BMW R1100S / R1200S Tech Forum (http://forums.pelicanparts.com/bmw-r1100s-r1200s-tech-forum/)
-   -   Larger Tank (http://forums.pelicanparts.com/bmw-r1100s-r1200s-tech-forum/990647-larger-tank.html)
Chris Canning 03-15-2018 08:39 AM
Larger Tank
Some years ago I had an initial batch of larger tanks made (4/5) that came in at 22L there was then another batch made(6/7) which were slightly larger due to errr I think the technical term is cockup :) two tanks came in at 24.9L of which I have one the rest were 24L as you can imagine I was never keen on folks posting photos for the copiers to see but at some time there was always going to be a time when one appeared and here it is.
Info about the battery holder and the ECU being moved is incorrect neither need any attention not even on the 24.9L but you will certainly need an Odyssey 545 as a 680 will not fit if you go for a similar design.
Non ABS of course.
R1100S Extended range fuel tank - www.boxertrix.com
Chris Canning 03-22-2018 03:36 AM
I see the add has been changed now but i値l Leave the post as is,in fact my PC is sat between the standard battery holder the upright ECU.
adrianw 03-29-2018 10:38 AM
Hi Chris,
I've sent Kieron an email to see if he still has it.
I reckon my arse has a little more than 160 between stops in it.
Cheers
Adrian
Chris Canning 03-29-2018 11:05 AM
If you get it you値l wonder how the hell you put up with the smaller tank for so long just that little bit extra means stopping for fuel when you want rather than having too.
I知 still in contact with the guy who welded them for me and must still have at least 4 stock tanks in the loft :)
adrianw 09-07-2018 04:30 AM
Hi Chris,
What size o-ring is that on the filler neck?
My 1999 ring is too big by a diameter of the ring (~5mm).
Yes you are quite correct, I now need a Odyssey 545 to replace the tall odessy I have in there.
Cheers
Adrian
Chris Canning 09-07-2018 07:29 AM
Blimey now your asking as I recall it痴 always been way to big but with a spray of WD jam everything underneath in the groove and press down on the neck before it all springs out but in the mean time i値l Check if I have a spare or maybe one of the guys on here know.
adrianw 09-08-2018 07:48 AM
Hi,
I checked realoem and there is only one part for it, so it must be right.
I ordered a new one and a number of fasteners for the body panels and the screws around the airbox as they were all getting a bit too roundy.
I also got a second hand dampner for it, as my groans and creaks antil it is warm.
I got the ACF-50 out as well.
Good soaking.
Cheers
Adrian
BadToTheBown 09-09-2018 06:34 AM
The O-rings often soak up the petroleum and grow. I've found if I let them dry out for several days to a week they shrink back to size...good luck...
adrianw 09-11-2018 11:11 PM
oh look it fits now - I too now have a spare O-ring....
DCooper 09-12-2018 11:10 AM
A few minutes in boiling water accelerates the process.
tomvv11 09-16-2018 08:41 PM
Is this still a happening thing? Think it would it work on an '04 with servo ABS? Any idea on price range? 6 liters is not a huge amount of fuel, but would sure take the worry out of long intervals in the Western US, as well as forestall that annoying light coming on a commuting day earlier than I would like.
Chris Canning 09-17-2018 04:12 AM
Currently in the South of France en route to the Aragon GP but the simple answer to your question yes I can still get them done,but postage to the States would be into the stratosphere unless you know someone visiting the UK who could take one back as hand luggage.
sgoodwin 09-17-2018 04:23 AM
I thought they only worked on non ABS or ABSectomy bkes?
Chris Canning 09-17-2018 08:58 AM
Correct.
Copyright 2018 Pelican Parts, LLC - Posts may be archived for display on the Pelican Parts Website
