Rear Fender
Tired of washing the back end al the time. I need a rear hugger fender for my 1999 R1100S. Looking for suggestions on options. Carbon fiber would be nice, but they appear pretty expensive, unless there is a good source that you know of that is moderately priced.
Old 03-13-2018, 06:00 PM
terrym's Avatar
Pyramid has plastic or carbon - Pryamid R1100S Huggers Can't speak to the fit/finish, but I've used their front extender successfully in the past.
Terry
2016 Cayman
2004 R1150S
Old 03-14-2018, 08:32 AM
Pretty sure the Pyramid hugger is designed for the 170 rear tire. Might not fit well if you have the wider 180 rear.
Anecdotal evidence: Pyramid Plastic Rear Hugger
Kyle with an R = Kyler... Get it?
Old 03-15-2018, 06:55 AM
Registered Agitator
sgoodwin's Avatar
It works fine with a 180 rear. The problem I had was it was flexing all over the place at speed in the mountains so I jettisoned it for a shock sock. Seems the single sided mount wasn't stiff enough to keep it from moving around when I was screaming through the twisties.
Old 03-15-2018, 07:02 AM
Grumpy's Avatar
Try Ilmberger (Ilmberger Carbon)
Not inexpensive, but an excellent product. It looks great and is nice enough that I recently bought a second one to replace the one that broke after 15 years of use.
Old 03-28-2018, 10:35 AM
Tirefriar's Avatar
Need to be careful with 'inexpensive ' rear huggers as they can break off their mount and jamm themselves between the front of rear tire and swing arm. I have an Ilimberger but have not put it on my bike as I'm not sure I'd be happy with the look. Luckily, I have access to a very good pro pressure washer so it's not an issue for me
Old 03-28-2018, 02:36 PM
R1100s
Neoprene and velcro wrap shock cover works well..easy to make.
2009 HP2 Sport (sold)
2006 R1200s Remus exhaust, K&N, ilmberger carbon hugger, Ohlins, ABS, Heated grips, Wide Rear Wheel
2006 Subaru WRX STI S204 #318 / 600
Mercedes-Benz B-Class B180 BlueEFFICIENCY
Old 03-28-2018, 04:32 PM
buzzerbee's Avatar
Do you know of an instance when this has happened?
Old 03-28-2018, 06:53 PM
Tirefriar's Avatar
Here are just a few threads to peruse but i think there are more out there:
Ilmberger Hugger Safety Strap
Wierd thing happened
Old 03-29-2018, 08:23 PM
Registered Agitator
sgoodwin's Avatar
Have a friend follow you with one of these on your bike with a video camera, you'll see why I dumped mine. They move all over the place at speed regardless of brand. A shock sock such as from Ohlins keeps it clean & weighs next to nothing.
Old 03-30-2018, 05:29 AM
smddanny's Avatar
A couple layers of carbon uni on the underside stabilize the hugger.. keep it clear of a 180
Bikes:
2007 R1200S, 99 R1100S, 2008 K1200S, 2009 Moto Guzzi Griso, 2014 Stelvio, 1975 Kawasaki H1, 1970 Honda CT-90
Old 03-30-2018, 06:28 AM
