'07 R1200S
hellfishtat's Avatar
Bar end weights for helibars
Apparently, my R1200s had throttle meister throttle lock on the stock bars and I never knew. I just finished installing the helibars that came when I bought it and they donít work. Any suggestions on what I should buy to replace them? Anyone interested in buying a throttle lock for their hexhead
Old 04-03-2018, 03:44 PM
Droptarotter's Avatar
That's odd because I have a Throttlemeister on my Helibars?? Maybe you can just change the bolt?? Of are you having another kind of fitment problem?
Cheers
09 HP2 Sport,07 R1200S,05 KTM 640 Adventure,00 KTM 520 EXC,85 Yamaha RZ350,82 R100S,72 Hodaka 125 Wombat
Old 04-04-2018, 07:38 PM
'07 R1200S
Cheers
my helibars have squared/round ends. Not the cone shaped ones like the stock bars.
In order for me to make the bar end meet the handgrip, I have to move them about 1/2" away from the clamp, and then I have a clearance issue with the fairing. I'll take some picture and see if you can provide anymore help.
Cheers!
Old 04-06-2018, 11:05 AM
Ok, but it's been 10 years since I installed mine so need to find the stock bar ends to see how they attached??
I do remember that I never had the Throttlemeister installed on the stock bars.
Cheers
Old 04-07-2018, 09:39 AM
'07 R1200S
Iíve gotten the throttle side handgrip working OK. But on the left side Iím having issues. With this screw installed between the grip and the highbeam low beam housing the barend weight thereís 3/8 of an inch away from the end of the grip
Old 04-07-2018, 10:41 AM
'07 R1200S
This is with the screw not installed. I looked to see if there was another tapped hole in the Helibars, but there was not.
Old 04-07-2018, 10:53 AM
