sɹǝʇndɯoɔ sǝʇɐɥ
BikerMiker's Avatar
Wheel Balancer
I'm thinking about purchasing a wheel balancing kit from Marcparnes.com because
I'm ****ing sick of arguing with people. Anyone have any experience with these
good or bad? Any other recommendations?
The local Honda shop can't get it right (front wheel only). Their machine keeps
giving different readings every time they put the wheel on and then they even
showed me how they can do it by hand...
Who am I to argue with Mr. cocksure with 35 years of experience? Why is the
wheel still finding a heavy spot on a static balancer (he tells me this is good, right
in front of my face)?
I'm sorry a balanced tire should not return to a heavy spot.... Or have I been wrong about this all these years?!
Sorry.... Rant over....
Mike
'83 R100RS
'07 R1200S
'07 DRZ-400s
Last edited by BikerMiker; 04-04-2018 at 04:54 PM.. Reason: fixed... not me cocksure
Old 04-04-2018, 11:59 AM
Talk Less, Say More
ckcarr's Avatar
Location: Moab Utah. Home of wierd red & orange radioactive stuff...
I have one. Personally, I think it's great. And you're no longer at the mercy of anyone. I had wheels balanced at a dealer once... but they weren't. Couldn't go over 90 mph. I thought something else was wrong... Re-balanced myself with the Marc Parnes balancer and got them perfect... Not a wisp of vibration.
You just have to be patient working with it..
cRaIg CaRr
2000 R1100S, 2000 Dyna FXDX, 2015 rNineT. 2016 F800GS, 2016 Jeep Rubicon. 2001 Corvette, 1978 Porsche 928. Schwinn Homegrown MTB & Fastback Road Bike. 22 pairs of shoes. 44 bottles of beer.
Time Marches On: 2015 F800GS, 2010 F800GS, 2007 R1200S, 2003 Dakar, Buell 1125r, 2001 F650GS. 1999 F650. 1998 HD Sportster Sport. 2010 F150, 1995 GMC Sierra ALL GONE
Old 04-04-2018, 12:54 PM
sɹǝʇndɯoɔ sǝʇɐɥ
BikerMiker's Avatar
I pulled the trigger and ordered it. I'm done with this dance.
I feel like this happens way too often.
Mike
'83 R100RS
'07 R1200S
'07 DRZ-400s
Old 04-04-2018, 01:39 PM
Worth the money in my opinion. A friend invested in a No-Mar tire mounting kit and we use my balancers to do his, mine and a couple of others tires. Note that we strive to get the best balance of the tire/wheel by checking the balance before setting the beads and rotating the tire on the rim. The last tire went from 3 oz. to less than 1 oz. that way. Take your time to get the best results.
Frank
'17 R1200RS, '03 R1100S BCR, '85 K100/1100RS, '11 R1200RT (gone), '05 R1200ST (gone), '99 R1100S (gone), '96 Ducati 900SS/SP (gone), '92 K100RS (gone), 34 years-500,000+ BMW miles
Old 04-04-2018, 03:18 PM
sɹǝʇndɯoɔ sǝʇɐɥ
BikerMiker's Avatar
Mmmmmmmmmm.
I can feel the OCD coming on now....
Mike
'83 R100RS
'07 R1200S
'07 DRZ-400s
Old 04-04-2018, 04:19 PM
Droptarotter's Avatar
I have a Parnes balancer and a NoMar tire machine.......don't have to go to a dealer to get any wheels done.
I had Marc Parnes make me a special set of balancer cones so I could balance my BST rear wheel. Stock Parnes BMW cones will not work!
Cheers
09 HP2 Sport,07 R1200S,05 KTM 640 Adventure,00 KTM 520 EXC,85 Yamaha RZ350,82 R100S,72 Hodaka 125 Wombat
Old 04-04-2018, 07:43 PM
I got the Goplus balancer on Amazon last year ($32). It works really well. My bro, the MC mechanic, was impressed with how accurate and sensitive it is. Works on my R11S and K12RS wheels.
https://www.amazon.com/gp/product/B01IV9P77M/ref=oh_aui_detailpage_o09_s00?ie=UTF8&psc=1
Old 04-05-2018, 04:58 AM
tm1100s's Avatar
I also have a MarcParnes balancer setup. Works.
Our rear wheels can be fitted to a dynamic balancer used for cars and that works, too. The fronts won't fit on a dynamic auto wheel balancer unless it has a small diameter shaft.
If you balance a tire dynamically (spin balance, if you will) and then put it on a static setup, it won't read the same. There will be a heavy spot. The dynamic balancer picks the best balance using both types, static and dynamic, and applies the result. That's the best way I can explain it. I've tried this several times and thought I was doing something incorrectly, but either way, the tire ran smooth. That, along with our m/c tires being more narrow and usually lighter anyway, and a static balance being off a bit dynamically, it doesn't give the full adverse effect (or is it Affect). That's also the best I can explain it. Any physicists in the stands?
How complicated does it get? Some auto tires come marked with a heavy or light spot in red or yellow and also with blue, green, and more spots for first, second or third harmonics affecting the balance.
It gets complicated, but you can't use most of that info anyway, so who cares?
Anyway, never had a problem with the Parnes.
tm
(R12, R11, R1) + 00 then S, S, /7
Old 04-05-2018, 04:36 PM
sɹǝʇndɯoɔ sǝʇɐɥ
BikerMiker's Avatar
Let me ask you this as you probably have experience with this.
If you put a wheel on a dynamic balancer and it shows 20g is needed, you stick the
weights on, spin it again and it 0s out.
Great.
If you take that wheel completely off of the balancer and then put it back on, spin it,
would you expect to see the wheel at 0 or would it need 20g again?
Mike
'83 R100RS
'07 R1200S
'07 DRZ-400s
Old 04-05-2018, 07:10 PM
tm1100s's Avatar
Great.
I would expect a wheel and tire combo that was balanced and 'zeroed', then re-installed, to still be balanced. After adding the 20g I certainly wouldn't expect to need the same amount of weight to get it balanced again. Having said that I've encountered these things:
I use a Parnes balancer for m/c wheels and haven't had a problem. I've balanced rear wheels on a spin balancer and had them not match the static balance but both work. Obviously there are dynamic forces at work that we can't resolve on a static balancer but we minimize it by splitting the weight required between both sides of the wheel. That's basically a guess and an approximation because we really don't know where or what side of the wheel has the imbalance. Any problem I've had with the Parnes was always related to the way the tool was installed and setup and mostly with the cone not going all the way through the seal to capture the bearing. Wheel not centered properly. Locking pins out of position. Operator error.
I've also had a couple of issues with the dynamic (spin) balancers, mostly operator error again with the wheel not being centered on the shaft properly, the wheel not tight enough and not maintaining it's position on the shaft, but also having the machine lose it's orientation or calibration and needing to be rebooted to get it's 'calibration' back. The last one is odd because the result is asking for all kinds of different weights and positions that make absolutely no sense. But if the problem is a machine issue, then what?
All of this assumes that inside the tire is clean and dry, no lube, moisture or beads floating around.
tm
Old 04-06-2018, 08:49 AM
Talk Less, Say More
ckcarr's Avatar
Bringing up the tire dots, good point. Some people like me, forget they're there...
cRaIg CaRr
Old 04-07-2018, 07:15 AM
wiggledbits's Avatar
Send a message via AIM to wiggledbits
Inexpensive Balancer
I have the same type balancer and so far even without the BMW adaptors 110 mph (only on a track of course!) and no problems. I think it was under $50.
Old 04-09-2018, 11:08 AM
tm1100s's Avatar
Looks very similar to this one:
https://www.harborfreight.com/motorcycle-wheel-balancing-stand-98488.html
I admit, I bought one a while back for only $19 just for the stand to use the Parnes stuff.
Price is up. Must be making up the whole $500B deficit just on these things.
tm
Old 04-09-2018, 07:14 PM
sɹǝʇndɯoɔ sǝʇɐɥ
BikerMiker's Avatar
So I got the balancer and went to work.
The balance seemed to be pretty close from the shop.
I had a shelf sitting on the floor in the garage and spun the wheel on the balancer with the shelf close to the tire's edge.
There was a ~4" flat spot in the tire. No doubt.
Tire's been replaced, I balanced it and all is good with the world again.
Of course the shop manager seriously doubted that it was the tire but exchanged it anyway
without checking it. Said he was too busy to check and I'm on my own if I had trouble with this new one too.
That rubbed me the wrong way.
This isn't the first time I've purchased a bad tire.
Mike
'83 R100RS
'07 R1200S
'07 DRZ-400s
Old 04-12-2018, 11:51 AM
Looks exactly like my Goplus from Amazon.
Old 04-14-2018, 07:54 PM
r1100sp's Avatar
Mine, also from Harbor Freight, has served me well over many years. I replaced the 2 pair of HF wheels with better, free-turning ones from the local hardware store. It's produced perfectly balanced wheels for both the street and track.
Old 04-17-2018, 01:53 PM
Gasteropod Rider
Meeni's Avatar
You guys are unlucky. Brought my wheels to a local shop, while I was still talking to the foreman I could see the tech already checking the bearings for play and lube even before leaving to the shop. Wheels were perfect.
Old 04-17-2018, 03:33 PM
Talk Less, Say More
ckcarr's Avatar
No... you were just lucky!
(We had the usual luck. The center of the bell curve)
cRaIg CaRr
Old 04-18-2018, 05:49 AM
Barback King
Rapid Dog's Avatar
I've used a Marc balancer for years. In fact bought it for the S.
When I get tires mounted I telll the shops to forget the balancing. It's never right.
Doing it yourself is easy insurance.
Get plenty of stick on weights.
R11S CNC BARBACKS
'13 F800GT, '91 R100GS, '09 KTM 450EXC (Yeah, I had an S once)...
Old 04-18-2018, 07:14 AM
Barback King
Rapid Dog's Avatar
New Metzeler NEXT on my 2017 GS...
https://rexdog.smugmug.com/Motorcycles/2017-GSW/i-mwKz59x/A
R11S CNC BARBACKS
Old 04-18-2018, 07:17 AM
