R1100S Rear Brake Caliper - broken bleeder valve
Hmm - had the bike in to mount new tires, erred in asking the shop to change the brake and clutch fluids - now I have a broken bleeder valve on the rear caliper.
I am told that BMW does not sell the threaded insert that the bleed value screws into, so am looking at $550 ish for a replacement. It looks like someone in the UK sells an after market insert ($25) which is appealing, but shipping looks like they use the slow boat.
Anyone have any experience with a repair for this issue.
Old 05-21-2018, 03:09 PM
04 R1100S
R1100S-Slick's Avatar
Same issue here, Hopefully someone has an answer....!?
Thx
Slick....
Old 05-21-2018, 05:09 PM
850dunstall's Avatar
check max bmw
on the fiche site at MAx bmw under the rear brake caliper, max bmw lists
SBBMWS SPEED BLEEDER M7XM12 W/SB7100S
which has a threaded plug and bleeder screw, you might want to call them
$20.00 USD worth checking out
claus
IBA, 03r1100s, 11f800st, 73norton, 74norton
Auf Adlers Fluegeln getragen...
Old 05-21-2018, 05:59 PM
Used caliper on eBay? You have Brembo or the BMW calipers?
2001 RS1100S Light. Black on Black w/carbon fiber bits.
Old 05-21-2018, 06:08 PM
Thanks that's it - with shipping a lot less than the 3 week listed for the UK folks.
Old 05-21-2018, 09:35 PM
Twin Thumper, IYKWIM
I don’t understand why an experienced shop wouldn’t drill into the broken bleeder and use an easy-out/bolt-extractor. What’s the worst that could happen, you end up with a dead caliper? They’re calling it dead as it is!
Anyway, get thee to eBay and line up a contingency caliper. I don’t know what “threaded insert” you’re talking about, but definitely don’t helicoil a caliper. That’s madness.
Old 05-22-2018, 12:52 AM
RBMann's Avatar
As mentioned above, you can replace the adapter with a standard bleed valve. If you are obsessed with having the adapter I can probably find the one I removed.
RBMann- The road is his workshop, and his trips are opportunities to do much needed repairs. -Bill S.
* '17 Africa Twin * 2000 S, color-Salmon 100K+
* '09 F650GS twin-pending sale
* '83 GPZ 550-gone to a newbie * '75 CB400F-retired to AZ.
Old 05-22-2018, 10:49 AM
Don Ro's Avatar
A generous man, as always.
I don't come here often anymore, but it's great to see the enthusiasm of new R11S owners.
A truly splendid bike, I'll never sell mine...I don't get to ride my '99 much any more (8k miles)...have others to ride.
Don
"Fully integrated people, in their transparency, tend to not be subject to mechanisms of defense, disguise, deceit, and fraudulence."
- - Don R. 1994, an excerpt from My Ass From a Hole in the Ground - A Comparative View
Old 05-23-2018, 05:19 AM
tm1100s's Avatar
Looks like you can make the adapter from a 12mm bolt cut to length, drill and tap for any bleeder you fancy.
Might as well make it easy.
Speed Bleeders
tm
(R12, R11, R1) + 00 then S, S, /7
Old 05-23-2018, 07:29 AM
Buy the one on ebay and steel the parts you need (locktited into the body) or just wait for the right parts...do not recommend easyout, we had a laser on our ship to just cut them out after someone broke another one off (they're case hardened but will snap like anything hardened and brittle). Also consider the fitting that screws into the caliper is machined for the bleeder that goes into it. The fitting will not make a good bleed itself...helicoil can work but not recommended, it's actually stronger but it's some times a PITA to keep it from leaking under pressure so you have to seal them, just skip this headache as suggested...best of luck...
2001 R1150S - project bike
2004 R1150SR - Project Touring Bike
2005 Honda RC51 SP-2 project bike
2014 Ducati Hyperstrada - fun touring bike
Old 05-23-2018, 07:46 PM
Just get the kit from Max BMW. Speed bleeders are the way to go, anyway. Makes it SO much easier to change fluid.
Old 05-25-2018, 08:11 PM
