Gasteropod Rider
Meeni's Avatar
Gas tank cap gasket
The gasket on the filler cap is dried up and craking. I can't find the part number for this. To be clear, not the gasket between the tank and the filler neck, but the gasket on the filler cap itself (see image). Surely the gasket can be obtained without buying the rest of the aluminum cap assembly....
Old 05-24-2018, 09:28 PM
05 Gasket, filler cap 1 16117657172 $5.38
Old 05-25-2018, 02:04 AM
Gasteropod Rider
Meeni's Avatar
Thanks, but I think that's the one that goes on top, under the key flap. I'm searching for the one we see on the picture here behind the red ring.
Old 05-25-2018, 06:47 AM
I just went through a couple of sites. I don't see it anywhere. Might buy a used cap on eBay and pop the gasket off it and out it on yours.
2001 RS1100S Light. Black on Black w/carbon fiber bits.
Old 05-25-2018, 03:58 PM
https://www.ebay.com/itm/BMW-Genuine-Motorcycle-Fuel-Tank-Filler-Cap-259E-259R-259S-259T-89V3-K14-K25-K25/123100525626?epid=1323803421&hash=item1ca95cf43a:g:16kAAOSwqxRa4SGn&vxp=mtr
This listing is on eBay for the cap. The diagram on it shows three rings or seals for the cap. Not sure where that drawing came from.
Old 05-25-2018, 04:25 PM
Is the diagram from an R1200RT -
2004 R1100S
Old 05-25-2018, 10:05 PM
I did an eBay search for R1100S fuel system. That auction popped up.
Old 05-26-2018, 04:16 PM
Gasteropod Rider
Meeni's Avatar
Looks like its P/N 16111455096
30x56 flat gasket.
Got the old one out, it measures 30x54, but it may have shrunk and such part does not appear to exist.
Old 05-30-2018, 06:37 PM
Gasteropod Rider
Meeni's Avatar
Looks like a non-trivial task to put it back on.
Found this info on the K bikes. But the r11s cap is slightly different in that the mushroom insert at the very center that he pops with a giant plier does not appear to be removable (what would be the black center part in front of the red ring). Ideas?
https://www.youtube.com/watch?v=Mwpt9IumBCc
Old 05-30-2018, 07:53 PM
Meeni :
Good work finding out it's part number 16111455096.
The BMW fiche diagram looked nothing like the actual flat gasket.
Doesn't look like you'll have any problems with an outside diameter of 56mm - as long as it covers the gasoline port.
How did you manage to get the old one out ?
Did you use a pair of pliers on the center black part ?
2004 R1100S
Old 05-31-2018, 08:28 AM
Gasteropod Rider
Meeni's Avatar
No, just rammed a screwdriver between the metal spring ring and the gasket, that popped it off quite easily. Now the problem to put a new one in is that one has to press it in place, but at the same time, the red ring pushes itself down and closes the gap. So ideally I would have to remove the black centerpiece but it doesn't look like it actually can be removed.
Old 05-31-2018, 03:51 PM
If you pull "outward" on the flat gasket with needle nose pliers, would the gasket get thinner and slip in? Might also wipe it with dish soap or WD-40 to make it slippery.
Old 05-31-2018, 05:26 PM
RBMann's Avatar
You me look and my gasket is cracked too.
Found a gas cap kit with that gasket included. Seems to share parts with the R1150GS.
Fuel Tank Gasket Kit - BMW R Oilhead R850, R1150; 16 11 1 455 096, 07 11 9 900 019 / BMW
RBMann- The road is his workshop, and his trips are opportunities to do much needed repairs. -Bill S.
* '17 Africa Twin * 2000 S, color-Salmon 100K+
* '09 F650GS twin-pending sale
* '83 GPZ 550-gone to a newbie * '75 CB400F-retired to AZ.
Old 06-24-2018, 10:12 AM
