LinkBack | Thread Tools | Rate Thread |
Member w/ Title Problems
2007 X3 N52 3.0si Issues
I have a 2007 x3 as well. Check for oil in the wells. I needed to change the valve cover gaskets due to oil leaking in the spark plug / coil wells. The gasket kit should come with 6 small gaskets for the plugs / coils and the large valve cover gasket. Oil in the well will cause the coils to swell and misfire. Also check the connectors to the coils, had a frayed wire too. Good Luck-
Thread Tools | |
Rate This Thread | |
