Go Back   Pelican Parts Forums > BMW Forums > BMW Technical Forums > BMW X1, X3, X4, X5 & X6 Forum
BMW x3 28i Engine Light Codes
I recently bought a used 2013 x3 which already had the fuel injectors and turbo booster replaced by BMW. Upon inspection engine light codes 118602 (lambda Probe Before CC mixture control exhaust too lean after CC) and 128301 (lambda probe in front of CC system check signal too rich) were shown. The codes were clear and two days later another CC code and an 02 code appeared. Should I be concerned about these? I originally thought the engine light was for the gas cap because when filling up the light came on and went out a few days later, then when at 1/4 tank it came on but went out the day after I filled up. Not used to all these sensors and codes appearing because my previous car was a 2007 camry. thank you
Old 07-08-2020, 08:38 PM
