Go Back   Pelican Parts Forums > BMW Forums > BMW Technical Forums > BMW X1, X3, X4, X5 & X6 Forum
2004 BMW X3 Doors not locking
Greetings,
My 04' X3 just developed this weird issue with locking... I can't use my key fob to lock and unlock my doors. I can lock and unlock my doors from inside of the car by using the central locking button. Another weird thing is that, when I removed the key from the ignition, the chime continuously chimed until I step out the car and shut the door.
I tried reprogramming my 1 yr old key and that didn't do anything. I tried several times and several different type of programming that I found on the NET. I believe the key is still good. I think the ignition switch might be bad.. Not sure. The only thing I haven't done is, disconnect the battery.
I am desperate and I don't want to take to the Stearlership for this.
Please help if you had this problem before.
Thanks!!
Old 08-23-2017, 01:56 PM
Administrator
Dmitry at Pelican Parts's Avatar
Hello - before spending any money or taking it in to the shop, try pulling the codes. This should give you a definitive answer as to where the problem is to start troubleshooting. Please let us know if you have any questions!
Old 08-23-2017, 03:25 PM
Sorry, no codes or check engine light.
Old 08-30-2017, 08:36 PM
