Go Back   Pelican Parts Technical BBS > 2- BMW Forums > BMW Technical Forums > BMW X1, X3, X4, X5 & X6 Forum
2007 BMW X3 3.0si Fault codes
I have a 2007 BMW X3 3.0 si. Lately, the check engine light came up and the car was scanned with OBD II scanner, and it came out with the following fault codes viz P1415, P0174(pending code), and C0300. What do I do to correct these fault codes?
Old 09-03-2017, 09:23 PM
  Pelican Parts Technical Article Directory    Reply With Quote #1 (permalink)
Administrator
Dmitry at Pelican Parts's Avatar
Hello and welcome to the forum Erin - based on codes you have a misfire and a fault in your secondary air injection system. Can you give us a bit more info on how the car drives? I'm attaching a link to a DIY tech article from our site that may help you address the secondary air system issue that you're having.
Pelican Technical Article - BMW-X3 - M54 Engine Secondary Air Components Replacement
Old 09-05-2017, 09:34 AM
  Pelican Parts Technical Article Directory    Reply With Quote #2 (permalink)
I was on a highway traveling to cover a distance of about 120 miles. I was making 80mph when suddenly the engine stalled(stopped), I pulled over, started the engine again and the car moved. In short, the car did the same thing before I completed the trip. On my way back I experienced the same.
Old 09-05-2017, 09:56 PM
  Pelican Parts Technical Article Directory    Reply With Quote #3 (permalink)
Copyright 2017 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
