Go Back   Pelican Parts Forums > BMW Forums > BMW Technical Forums > BMW X1, X3, X4, X5 & X6 Forum
X3: Acrid Smell, Low Coolant ?
Would be great to have your thoughts :
1) We have an acrid smell in the cabin. Sometimes it smells like cigarettes, sometimes closer to coffee. It only smells when the heat is on - on / off verifiable that the smell goes away then comes back.
2) About 500 miles ago I topped up coolant with about a liter, because the low coolant light went on. It hasn't come back yet.
So my guess is that there is a leak in the heater core. Anyone have any other guesses?
Has anyone tried to pressure test the heater core with air to check it?
2007 X3 has 118k miles
Bruce
2002 C4S 105kmiles
Boston MA
Old 02-03-2018, 10:52 AM
You might be able to find a cooling system tester with adapters to fit the hoses, limit air testing to less the. 15 lbs. See if you can locate any sign of coolant inside the cabin near the firewall, if the heater core is bad, you should be able to find traces of coolant in the heater ducts as well.
Old 03-05-2018, 10:12 AM
Invest in UV dye which you can add to your coolant. Only costs a few bucks but saves a lot of screwing around.
Old 06-06-2018, 08:16 PM
