-   BMW Z3/Z4 Forum (http://forums.pelicanparts.com/bmw-z3-z4-forum/)
-   -   Trunk Light Does not Work (http://forums.pelicanparts.com/bmw-z3-z4-forum/1007829-trunk-light-does-not-work.html)
HarryD 09-14-2018 12:44 PM
I noticed my trunk light was not working. I checked the bulb and the fuse and they are ok. I checked for voltage at the bulb base with none found.
I read that the switch for the light in in the rear trunk latch. I removed the trunk latch and found a two wire connector (with brown wires) laying loose in the area. It appears to the be the same wire on the lamp holder.
I am unable to find where this connector plugs into. There was no area on the latch mechanism for this wire to plug into.
Does anyone have a picture showing where the connector is located or can tell me where to look?
HarryD 09-17-2018 08:19 PM
After testing, I verified the wire between the trunk release and the light was broken. I removed the flex connector between the trunk lid and the body. I found the brown with yellow stripe wire which provides the ground for the light was broken. Soldered in a splice and all is working again.
