Go Back   Pelican Parts Forums > BMW Forums > BMW Technical Forums > BMW Z3/Z4 Forum
Water leak
In the process of removing the air from my cooling system after an ET replacement in my 2000 323ci I noticed a water/coolant leak coming from behind the largest pulley but its only when the front is jacked up. The higher it goes, the worse the leak but when the car is on the ground theres no leak at all. Any idea what the problem could be? This is while the car is NOT running with the key in the OFF position. Could it be the seal behind the water pump maybe?
Old 02-27-2019, 11:39 PM
